R50/53 Boost
Old Jun 11, 2007 | 11:59 AM
minipooper02's Avatar
minipooper02
Boost
I want to install boost gauge and Air/Fuel ratio in my car. I dont want to spend 150 buck for the alta pods and what not. Is there a cheaper solution?
thanks,
Justin
Old Jun 11, 2007 | 12:01 PM
Loony2N's Avatar
Loony2N
Yep. scangaugeII. look at their site.
Old Jun 11, 2007 | 12:10 PM
Jenn B's Avatar
Jenn B
"Electrical" forum.
There is a stickied thread at the top.
Old Jun 12, 2007 | 05:30 AM
minipooper02
what does that have to do with what I was asking?
Old Jun 12, 2007 | 06:02 AM
Partsman's Avatar
Partsman
Legion_of_Doom
You could have someone make a simple pod out of some aluminum tube...
...here it is finished...
https://www.northamericanmotoring.co...ad.php?t=86989
I just use the ScanGaugeII to supplement these gauges...
Old Jun 12, 2007 | 06:32 AM
chuckt's Avatar
chuckt
Helix sells a simple bracket ($40) for the AM 2-1/16" gauges. You don't need any cups, just mask off the face, bezel... and paint the rest black. There are some examples in the "show your gauges" thread.
Old Jun 12, 2007 | 10:13 AM
jasonsmf's Avatar
jasonsmf
You think that maybe the scangaugeII will read boost and AFR? Just a thought....
Jason
Old Jun 12, 2007 | 10:21 AM
chuckt's Avatar
chuckt
I don't think you can get AFR form the OBD port, not with a narrow band O2 anyway.
Old Jun 12, 2007 | 10:35 AM
dwjj's Avatar
dwjj
The scangauge tells you whether you're open or closed loop. Open would be faults or startup, closed and you'll have basically a constant voltage-the computer should be using the O2 sensor data to adjust AF to keep it within a certain range.
Why do you need AF readout?
Old Jun 12, 2007 | 11:58 PM
rhubbard's Avatar
rhubbard
Old Jun 13, 2007 | 12:00 AM
rhubbard's Avatar
rhubbard
It has since been cleaned up a bit and and I redrilled the bracket to get a better grip on the gauge cup. I don't really like my setup though, so I'm going to start thinking of something new to do.
Old Jun 13, 2007 | 05:31 AM
minipooper02
nice
Is that with an alta pod or ______?____...
How did you do that? Looks good.
Old Jun 13, 2007 | 05:32 AM
minipooper02
Jason
I want gauges not digital scan readings.
Old Jun 13, 2007 | 06:49 AM
rhubbard's Avatar
rhubbard
they are prosport gauges in autometer carbon fiber cups. Everything but the gagues are autometer.
Old Jun 13, 2007 | 10:11 AM
minipooper02
..rhubbard has a PM
Old Jun 13, 2007 | 12:30 PM
Ryephile's Avatar
Ryephile
Justin, *waves Jedi hand* you don't want a boost and AFR gauge, you want to trade cars with me instead! *waves Jedi hand*
Old Jun 13, 2007 | 01:18 PM
minipooper02
Get some one to buy my car or trade me straight across. hahaha.. I want astro so bad...:impatient
Old Jun 13, 2007 | 01:20 PM
DixonL2's Avatar
DixonL2
Partsman: Sexy, that is. -Yoda
Old Jun 13, 2007 | 04:34 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks very much, I say. Much appreciated, your comment is. Sexy looking, gauges are.
Old Jun 13, 2007 | 06:15 PM
ImagoX's Avatar
ImagoX
I went with the Autometer "carbon fiber" boost gauge since I have the dark gray replacement gauge faces:
Old Jun 13, 2007 | 06:29 PM
rhubbard's Avatar
rhubbard
ImagoX, whenever you get a chance could you snap a shot of the back of your tach so I can see exactly how you have it setup?
Thanks.
Old Jun 13, 2007 | 07:17 PM
ImagoX's Avatar
ImagoX
Sure... this is one of the "long" gauge brackets - can't remember where I got it exactly but check the Stickied thread at the top of the Electrical forum- there are several links to it in there. The wires and vacuum hard line are wrapped in expandable black nylon sheathing (the same stuff I use to reinforce and stealth wires in PCs).
Oct 1, 2015 12:13 PM
patsum
Sep 30, 2015 02:10 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
EVMini
Sep 28, 2015 10:20 AM
mbatech
Sep 10, 2015 03:40 PM
