CravenSpeed Product Thread: The Stubby Camera Mount
Old Oct 26, 2018 | 01:10 PM
CravenSpeed's Avatar
CravenSpeed
Vendor
Hey Guys, just wanted to share a product on the forum that you might not have heard about. Many of you have heard of our Stubby antenna, but we also make a Stubby that doubles as a GoPro/Action Camera mount. Here's a word from our lead designer Steve:
We’re always looking to figure out ways to stick cameras onto our cars. We had an idea that by using the antenna base, we could provide a sturdy and secure location for an action camera that would provide an interesting point of view.
Using parts we already stock for other products in our lineup is always a good thing. We have these ball-pivot camera mounts that we’ve been using for our Passenger Camera Mount, and since we already make Stubby antennas for practically every car on the road, it was sort of a no-brainer to come up with something that would merge the two together. Think of the old peanut butter cup commercials when two people would turn the same corner, bump into each other and BAM! Something awesome is created!
Taking measurements, making a few prototypes, and running some road tests helped us develop an optimal shape that would be adjustable, aesthetically pleasing, and minimize vibrations. A cool side effect is that it still functions as an antenna! The lower half of the mount is machined and anodized locally. It was designed to flow into the upper which is an off-the-shelf camera ball-pivot mount. The finishing touch is a standard ¼-20 tripod mount that should function with pretty much every action camera currently on the market, so it’s extremely versatile.
Installing the mount is incredibly easy! Simply unscrew your antenna, spin the Action Cam Antenna Mount on in its place, and make some simple adjustments to aim your camera in the desired direction. No worries about failing suction cups or double-sided tape as your externally mounted cam is now essentially bolted on. It offers some pretty exciting footage too!
These mounts fit all MINIs that have a "screw-on" type antenna. If you have any questions, feel free to ask them here!
Check them out at cravenspeed.com
Old Oct 26, 2018 | 05:56 PM
vetsvette's Avatar
vetsvette
Moderator
Very nice! Excellent idea.
Old Oct 27, 2018 | 08:19 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I have this thing, and it’s a solid product!
Old Oct 29, 2018 | 09:24 AM
CravenSpeed
Vendor
Thanks! If you have any questions or ideas for how it could be improved, we'd love to hear from you.
Old Oct 29, 2018 | 11:48 AM
H_C's Avatar
H_C
Looks like a great addon.
Does it affect the radio reception? More specifically, AM stations.
Old Oct 29, 2018 | 12:17 PM
CravenSpeed
Vendor
It was not really designed with the idea of being permanent. You should still get all of your stations when it is installed though. If you are looking to shorten up the antenna all the time, this will look better:
https://www.cravenspeed.com/the-stub...enna-for-mini/
Old Oct 29, 2018 | 12:25 PM
H_C's Avatar
H_C
Good to know.
Presently, not looking for an antenna upgrade, but thanks anyways.
Old Oct 29, 2018 | 12:42 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
^ this
If radio reception is important to you, swap the camera mount when you get to your event, then change it back out when you leave.
Old Oct 29, 2018 | 12:45 PM
I_Forge_KC's Avatar
I_Forge_KC
Is that Inventor?
Old Oct 29, 2018 | 12:48 PM
CravenSpeed
Vendor
Originally Posted by I_Forge_KC
Is that Inventor?
Sure is. We've been using inventor for over a decade, we love it.
Old Oct 29, 2018 | 12:54 PM
I_Forge_KC's Avatar
I_Forge_KC
As well you should, with it being largely developed in your backyard
Based solely on that info, I'm going to buy a bunch of your wares, haha.
Old Oct 30, 2018 | 06:25 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Since we are talking about camera mounts...
I am currently rocking one of your Platapus tow hook plate mounts. Will your tow hook GoPro mount bolt to the front of the plate mount? (are the tow shafts the same?)
https://www.cravenspeed.com/gopro-ca...ount-for-mini/
https://www.cravenspeed.com/the-plat...ount-for-mini/
Old Oct 30, 2018 | 09:37 AM
CravenSpeed
Vendor
Good question! The stud design is the same, tapped with M10 thread at the end, but it is possible that the stud that came with your Platypus is not long enough to provide clearance for the GoPro mount. We like to fit the plate very tight to the bumper (it looks good that way and clears sensors). If you are not using a battery pack on the back of your GoPro it could work out. Just try mocking it up and send us an email support@cravenspeed.com and we can put together a cart with just the pieces you need.
Old Mar 11, 2020 | 02:29 AM
Thanh Äan's Avatar
Thanh Äan
thanks you
barenada
Mar 15, 2014 05:17 PM
stlcraig71
St. Louis MINI Club
Feb 23, 2010 11:16 PM
BlimeyCabrio
11
Sep 14, 2009 03:14 PM
Motor On
Electrical
Aug 5, 2009 07:59 AM
z3bum
15
Dec 19, 2008 04:12 AM
