Glad to hear Janets back home and wanting to get back to normalcy. Actually, Nick came home on tuesday. Trying to keep him from overdoing it so he will be able to make it to AMVIV.
I was over-reacting on the vibration, no worries there - I think it was all in my head. No comments. As far as the install goes - sounds like a plan. I'll have it over to you on Friday (3/12) morning so we can get the PSRS install done. Oh, if you're dropping the sub-frame does that mean you can do the p/s tank too?
Chief, are there other bushings to swap out to Powerflex when the subframe's down?
We can talk about those in the morning your main one is the lower engine mount and you have the BSH installed your next jump would be to the comp bushing. I will be there around 0800 what time are you stopping by?
I'll be there 10min till or so. We've gotta be at the office by 8:45am & I'd like to kick it for a sec before Cookie scoots by to get me.
Holy smokes Eddie - you weren't kidding about the PSRS! Twitchy & extremely direct (in a great way) is how I'd describe my steering now. I'll call Dave Kurata to have the alignment redone. I noticed I'm outta kilter & pulling to the right. Did you have this after your PSRS install? Not a biggie, just wonderin'.
Steve, talked to brake guy. sending elbow adaptors for brake lines. they even said they would send longer lines. should get them next week. thanks for brake job. Brakes work great!
Steve,
My MINI is leaking anti-freeze/coolant, and I can't pin point where its coming from. You replaced the thermostat already, so I'm thinking maybe its the water pump?
Steve,
Is it more toward the right hand side of the MNI? Also check the lower right side of the radiator where the tank attaches.
Ok, I realize I'm going to seem lame...but what are PSRS??
