R53 W11 engine for parts, rebuild
Engine - Internals
  • Engine - Internals - R53 W11 engine for parts, rebuild - Used - 2002 to 2008 Mini Cooper - Sf, CA 94103, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $1
    • OBO
  • Location Sf, CA, 94103, USA
  • Compatibility
Make Model Year
Mini Cooper 2002 - 2008
W11 engine block with 163k miles.  Motor was running when pulled but I wouldn't swap it without refreshing it first.  No SC or intake manifold.    Wiring harness is mostly complete.  Head was pulled and sold.  Available as a short block or parting out for cheap- just need it gone.
Thanks.
Old Oct 1, 2021 | 02:57 PM
jayuuey's Avatar
jayuuey
Update: The cylinder head was removed, cleaned, decked, and valves pressure checked. Its ready to drop in.
Old Oct 1, 2021 | 07:23 PM
jayuuey's Avatar
jayuuey
Head is no longer available.
Old Oct 1, 2021 | 08:00 PM
Nervos's Avatar
Nervos
I would take a crankshaft if journals are with the +0.25 to spec (which are 46 mm for piston rods and 48 mm for main bearings). Let me know if you consider the hassle to extract it, measure it (at least roughly with a caliper) and ship it to 98006
Old Oct 2, 2021 | 11:10 PM
jayuuey's Avatar
jayuuey
Ok cool. I'll get measurements in the day or so.
Old Oct 3, 2021 | 06:29 PM
Nervos's Avatar
Nervos
Will appreciate that!
Old Oct 7, 2021 | 12:26 AM
jayuuey's Avatar
jayuuey
Fyi, I am still working on it. About halfway to the crank.
Hopefully someone needs an oil pan, timing cover, piston & rods?
Old Oct 7, 2021 | 03:23 PM
jayuuey's Avatar
jayuuey
Crank and pistons are out now.
Cranks measurements look good. My calipers shows 47.9/48mm mains, 45.9/46 rods. All the bearings good to me so I cant imagine much wear on the journals.
Old Oct 17, 2021 | 12:16 AM
Nervos's Avatar
Nervos
Sent you a PM! (Thanks for measuring!)
Old Oct 18, 2021 | 05:44 PM
jayuuey's Avatar
jayuuey
Crankshaft no longer available.
