JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Please help....JCW pulley size
Old May 24, 2006 | 04:11 PM
SORMINI's Avatar
SORMINI
I need to know what kind of measurements you get when measuring the outside diameter of a JCW pulley and a stock pulley.
I am unsure if the dealer that did the JCW upgrade orgionally actually changed the supercharger to the right one. I am going to remeasure tonight, but i was wondering what measurement was normal. I found pulley measurements, but don't know how they are measured.
What actual measurement do you get from edge to edge on the outside face of the pulleys not including the belt?
Thanks....I need to know before i drive almost 6 hours to the pulley party.
Old May 24, 2006 | 04:18 PM
chows4us's Avatar
chows4us
There are several threads with multiple measurements here. Do a search on JCW pulley size
Much of it is right here in a sticky https://www.northamericanmotoring.co...ad.php?t=33923
Old May 24, 2006 | 04:31 PM
SORMINI's Avatar
SORMINI
I have measurements, but I need to know if I am measuring right? it is just the outside edges? do I measure just inside the lip where the belt lays? I am sooo lost....
Old May 24, 2006 | 04:55 PM
MINIAC's Avatar
MINIAC
Are you replacing the supercharger pulley or fitting an oversize crank pulley?
Old May 24, 2006 | 05:02 PM
SORMINI's Avatar
SORMINI
The supercharger pulley. My husband wanted to do a 15%, but when we got to reading more, found out that the JCW already have a reduction. But we are having a hard time figuring out if it is the right pulley. It looks much larger than the 15% reduction that his friend has on his mini. I did notice that the mini pulleys look like they have more of a ridge around the outside than the aftermarket ones do. That would make it look bigger and measure different.
Any ideas?
Old May 24, 2006 | 05:25 PM
Dr Obnxs's Avatar
Dr Obnxs
Measure accross the top of the ribs where the belt lies..
not the ridge that keeps it from wandering off. Stock pulley measures 2.588" plus or minus a bit.... I used a cheap caliper. A 15% should measure about 2.2", JCW a bit larger than that. If you didn't get a new SC, time to ***** up a storm!
Matt
Old May 24, 2006 | 10:32 PM
SORMINI's Avatar
SORMINI
Thanks. I think it is a reduced pulley. When I measure all the way from edge to edge (including the ridge) it still doesn't hit 2.58 inches. I am pretty sure it is smaller.
Old Aug 7, 2006 | 06:39 PM
SB's Avatar
SB
Finally found this thread in a search. Something that gave numbers. Sometimes the search feature can be a booger.
From the other thread.
stock 2.06:1 2.58"
JCW is 14.3% 2.355:1 2.21"
15.1% is 2.371:1 2.19"
17.1% 2.405:1 2.14"
19.8% 2.468:1 2.07"
I need to get some calipers to accuratly measure but from my measurments so far, against a stock pulley I have, they are identical. BTW, I have a factory JCW kit. The reason I checked is because of performance concerns based on my previous slightly modded MCS.
BernieCoop
Sep 10, 2021 03:15 AM
Mb460
35
Sep 18, 2015 06:46 AM
VanisleRyan
Sep 13, 2015 09:55 PM
boydie
Sep 13, 2015 05:06 PM
Emnotek
Sep 11, 2015 04:16 PM
