JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
ITG Filter Deterioration
Old Apr 5, 2021 | 02:46 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
It's been some 7,500 miles and a few years since I pulled and cleaned the ITG filter and, in preparation for an up-coming HPDE, I decided to do it again. To my surprise, it looked rather pathetic. Small pieces of the exterior foam were lying in the housing. The last time I cleaned it, I used the ITG approved NO-TOIL brand cleaner and oil and I started the procedure again. As soon as the filter hit the warm water, I could tell that this would not end well. The foam separated from the wire cylinder and the seam split. I'm certainly glad I decided to service the ITG because, had it continued to deteriorate, small pieces of foam could've been ingested into the throttle body. Since the AMSOIL filter is NLA, I've ordered a K&N RU-1330. If you haven't checked your ITG lately, I heartily suggest you do so.
Old Apr 5, 2021 | 07:00 PM
Racingguy04's Avatar
Racingguy04
I had a similar experience with the alta foam filter. I ended up going with the K&N RU-1520. I think the foam filters offer better filtration, but I don't like having to worry about them falling apart.
Old Apr 6, 2021 | 10:48 AM
NC TRACKRAT
Veteran: Navy
Same thing happened to the ALTA foam filter in our 2005 R53. Even using the prescribed cleaner and oil, they just seem to deteriorate. Anyone got a clue?
Old Apr 6, 2021 | 11:36 AM
nd-photo.nl's Avatar
nd-photo.nl
Same experience with the Pipercross filter here.
Old Apr 6, 2021 | 01:57 PM
Oldboy Speedwell's Avatar
Oldboy Speedwell
I was contemplating foam, and specifically ITG,
but keep reading stories of degradation and crumbling foam,
so will likely avoid.
I like the idea that they may flow better, but short lifespan is a major compromise given the cost.
I'm bummed out that Amsoil discontinued their air filters --- previous owner of my car had fitted a 3570 it seemed fine but the color was faded looking,
I replaced with a new one so it should last a good while, but in the meantime I've looked into what I want to go with next.
Using the Amsoil chart as a baseline for fitment...
...but I'm sure there's a little wiggle room there?
AFE offers a "build your own" option:
https://afepower.com/build-your-own-filter
You can also choose media type,
oiled cotton gauze or dry synthetic.
https://afepower.com/air-filter-media
Here's an off-the-shelf filter that is close to spec,
top is 1/2" smaller than Amsoil.
(dry synthetic version)
https://afepower.com/afe-power-21-35...y-s-air-filter
This wet cotton one looks like a good fit
and I like that it has the inverted cone top.
https://afepower.com/afe-power-tf-90...-5r-air-filter
Green Filters seem to be very well-made in both construction and materials,
a couple of videos doing comparisons with K&N showed the Green to appear "better built",
could not find a suitable universal fitment for JCW airbox tho.
https://greenfilter.com/universal-cylinder
Also while looking,
came across interesting test results,
like this:
And this one from
Autosalon Magazine, issue 51, Jan 2007
Old Apr 6, 2021 | 04:11 PM
nd-photo.nl
Also look at the transition at the neck, best would be a filter with a good velocity stack. I bought this one on Aliexpress and didnt think much of it, but it a very smooth transition in the neck. Cannot be used in the JCW airbox, but I just wanted to point out a much overlooked feature.
https://nl.aliexpress.com/item/33046865396.html
This is how the ITG (Vecchio Engineering, looks identical) and the Pipercross look
Old Apr 6, 2021 | 05:08 PM
NC TRACKRAT
Veteran: Navy
My ITG did not have the black molded ring at the base.
sandplasma
Jun 12, 2018 03:06 PM
AgentCoop
May 18, 2010 06:51 AM
Martin Brenneke
Nov 6, 2006 05:04 AM
redrocket
Sep 21, 2006 12:21 PM
ALTA2
May 15, 2005 09:25 PM
