JCW Tire pressures with 18" wheels
Old Nov 12, 2018 | 05:35 PM
dpcompt's Avatar
dpcompt
I just picked up my new JCW last Friday. I checked the pressure Saturday morning and the fronts were 3 lbs down.I pumped the fronts to 42lbs. I am thiking that I liked the tires at 39 all four instead 42f,39r. I am I in jeopardy of doing any damage or premature wear doing this?
Old Nov 13, 2018 | 03:37 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
What does the door sticker say? I would start there, and adjust in 1-2 psi increments up or down to get the feel you want. Take note of the max pressure on the tire, and don’t go higher than that.
Old Nov 13, 2018 | 02:46 PM
TheBigNewt's Avatar
TheBigNewt
What I found is that my car rides notably better (less harsh/bumpy) with the tires at 37 vs 40 (which I think is recommended on the door sticker). I doubt it makes any difference in anything else.
Old Nov 13, 2018 | 04:33 PM
dpcompt's Avatar
dpcompt
Lower tire pressures
I lowered the cold pressures to 40f, 38r and it seemed to slightly numb the on-center feel, which I like. I like quick steering, but not twitchy. My last car was a Cayman and it's steering was a little slower. Overall, I really like my JCW's handling, just trying to dial it to my taste. Thanks for your replies.
Old Nov 14, 2018 | 06:41 AM
cornjuice's Avatar
cornjuice
so long as the sidewall isnt laying over on turns..or saggy when parked, your running enough air pressure. Im on stock still and run 30psi all around.
*btw- going off the sticker on the door is as useful as asking Mini when you should change your oil! Those are recommended psi based on the load capacity of the car..and have no bearing on daily driving without passengers/cargo and crap runflats.
mininasser
Sep 14, 2007 02:36 PM
sanddan
Tires, Wheels, & Brakes
12
Jun 25, 2003 04:45 PM
pgrmstr
General Discussion
16
Jun 6, 2003 07:36 PM
friedduck
General Discussion
Apr 28, 2003 05:40 PM
truckeecollins
Mar 19, 2003 07:02 AM
