Tire pressures
Old Jun 13, 2003 | 08:04 AM
sanddan's Avatar
sanddan
I have Yokohama EVS100 tires on factory wheels in 205-50-16 size. What should the front and rear tire pressures be for best performance. These are on a MCS with madness swaybar and the rest stock.
Old Jun 13, 2003 | 01:28 PM
Alex@tirerack's Avatar
Alex@tirerack
33 Psi cold, start there! May want a bit more on the rears.
The higher you go, the more crowning, or fawning you risk (center rib premature wear)
Alex
Old Jun 19, 2003 | 06:21 AM
ice's Avatar
ice
I've looked around the car and in the manual, I can't find how much air I should put into the 17' rynflat performance tires that came with my Mini. Can anyone help me?
Old Jun 19, 2003 | 08:10 AM
Alex@tirerack
MCs -33 psi F+R cold
MC - 30 psi F+R cold.
Alex
_________________
Alex ext 294
800 522 8473
Tire & Wheel forum moderator
www.tirerack.com
alex@tirerack.com
Old Jun 19, 2003 | 08:28 AM
ice's Avatar
ice
Thank you sir.
Old Jun 20, 2003 | 02:32 AM
kbseto's Avatar
kbseto
how about for the MC Goodyear Eagle NCT 5 runflats 195/55R16?
Old Jun 20, 2003 | 03:02 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For MC with Goodyears use the same 30 psi F and R
I looked in the door jam on the drivers side and found the following:
For MC in 15 or 16" rims
For 2 to 4 people inflate tires to 30 to 35 psi
For MCS in 16 or 17" rims
For 2 to 4 people inflate tires to 33 to 38 psi
30 and 33 psi are good places to start.
Old Jun 22, 2003 | 05:28 PM
red03miniS's Avatar
red03miniS
what if i drive by myself during the week and with 4 people on weekends...should i adjust tire pressure ALL the time?
or can i put them all on 35psi, and be safe at that?
i ahve the 17 inch s lites with teh perfomance goodyear sp9000 runflats
Old Jun 22, 2003 | 10:30 PM
minihune's Avatar
minihune
It's up to you to see what works best for you. If you have the time and inclination to change the air pressure then you can adjust. I run mine with 33 psi only and if I know that I will need the 38 will I do the change but that is rare.
Too much pressure and the tires will run with a rougher ride and slightly less contact on the outer tread.
Too little pressure and the tires will run with less response (sluggish) and with more contact (increased rolling resistance).
I have even run them with 33 on the front and 38 on the back to try to reduce understeer when on the track.
It worked a little.
Old Jun 24, 2003 | 10:33 AM
red03miniS's Avatar
red03miniS
haha u got much more time than me
i will put it on 35 and leave it there :smile:
Old Jun 25, 2003 | 10:20 AM
HarryIndiBlue's Avatar
HarryIndiBlue
The door placard actually suggests different amounts for M+S vs. performance summers with 30 suggested for summers but higher for all-seasons (33 IIRC). I have the Goodyear Eagle NCT5 EMT 195/55R16s and find 30 is a bit low. I prefer 33 on the fronts and 33.5 on the rears. In winter with snows of the same size (Dunlop SP Wintersport M3 DSSTs) on I often prefer even more, 34 or so on the front and 35-36 on the rear for good cornering.
Note that suggested tire pressures are usually for 100MPH (160km/h) and lower. To go faster, you need higher pressure to prevent heat buildup. 170km/h needs 1 PSI more, 180km/h needs 2 PSI more and 190km/h needs 3PSI more. Higher speeds may need even more. 33PSI on the summer runflats should have you good to 190km/h or ~120MPH.
Harry
Old Jun 25, 2003 | 04:31 PM
Ryephile's Avatar
Ryephile
I tend to like higher tire pressures; I run 37 psi front and rear with my H-Sport'ed MCS with the stock Pirelli's
Old Jun 25, 2003 | 04:45 PM
cooper44's Avatar
cooper44
i like higher pressures as well, i run 35/36 in the front and 38/39 in the rears. except in the winter or early spring when the roads aren't quite as tacky. :smile:
Craig
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
