JCW 2017 F54 JCW manual transmission issue
Old Sep 10, 2018 | 08:48 AM
Ray Oliver's Avatar
Ray Oliver
I've had my F54 JCW for a year now and I'm having a strange issue with the manual transmission. I intend to take it to the dealer soon but wanted to know if anyone else had experienced this and if so, what exactly the problem was.
I'm having issues with second gear. Sometimes when I put it into second, it will then completely pop out of gear, or it sort of half pops out where the cars shakes a bit. This tends to happen at slow speeds, often in parking lots when I am just idling along or driving slowly in second gear. It doesn't typically happen when I am accelerating through the gears. It just started happening recently. Before this started happening, there were a handful of times when I would go into second gear and it would grind. At first I thought I was doing something wrong but I don't think I am. I'm thinking this might be related to this issue.
Any ideas?
Old Sep 10, 2018 | 08:55 AM
G26okie's Avatar
G26okie
Could be something hanging up the shift linkage or a 2nd gear syncro shot prematurely.
Old Sep 11, 2018 | 06:52 PM
zagman's Avatar
zagman
I also have a second gear issue. When shifting quick into second, it often will miss and grind. I wonder if there is a relationship?
Old Oct 1, 2018 | 08:03 AM
CPWillys's Avatar
CPWillys
I have had the same issue, a short shifter helped the situation by having a better feel of it. Mine has never popped out of second though.
Old Oct 2, 2018 | 12:12 AM
easter's Avatar
easter
Mine did this a couple of times but since I've been super meticulous about shifting as completely as possible and it hasn't happened since. Fingers crossed.
Old Oct 2, 2018 | 05:22 AM
02fanatic's Avatar
02fanatic
What short shifter did you go with? The manual suffers from too long of a throw imo....a well setup manual trans should be tight and extremely easy to shift up or down! This is not the case with the Getrag Manual Transmission in the F56 MINI! I still prefer it over the auto but it definitely needs to be tweaked. I do like the stock shifter shaft tho so I haven’t swapped it for a Craven or other short shift kit. Mine has never popped out of 2nd gear!
Old Oct 2, 2018 | 06:39 AM
CPWillys's Avatar
CPWillys
I did the Craven Short Shifter, I think the other issue with this transmission is the overly heavy Flywheel, but I am not ready to swap the clutch just yet.
https://www.northamericanmotoring.co...r-install.html
Old Oct 2, 2018 | 09:20 AM
02fanatic's Avatar
02fanatic
Thanks....nice work! I must admit that scares the heck out of me though....soooo much plastic that is prone to breaking! Nothing like the older cars where this swap is so much easier to do! You are to be commended for tackling that yourself.
Old Oct 5, 2018 | 12:52 PM
J_L's Avatar
J_L
The Craven shifter solves the sloppy feel and long throw. I doubt it would help with the popping out issue though, but worth a try! It isn't hard to install. For sure get their plastic bushing thing too though- that's one part that could get ruined on the way out.
Old Nov 12, 2018 | 09:18 AM
CarFreak427's Avatar
CarFreak427
I had this exact problem with my 2017 F54 Cooper S. Around 5k miles, second gear would not stay engaged without me holding it in place. Otherwise, it would pop halfway out and grind. It was the first case they had seen and it took a few weeks to get a new transmission from Germany, but it was replaced.
Old Dec 8, 2018 | 11:53 PM
kalphonso's Avatar
kalphonso
I drive a 2018 F54 JCW 6-sp Manual. 2nd gear popping into neutral started occurring around 3400 miles. Easily replicated @ Mini dealer service center. After a few days, ordered/ replaced transmission (what CarFreak427 did). Have added approx 4000 miles more to the JCW and haven't experienced the problem again - on this Mini. Purchased a 2018 F54 Cooper S just off Mini Executive Lease - roughly 7500 miles. Having this same issue with that one. When the girls get up from school next week, taking it to my local dealership (Mini of Sterling) and will have that transmission replaced too. All this under warranty and will petition Mini if it happens again even outside of warranty.
Best Wishes
- KAlphonso
Old Dec 19, 2018 | 09:53 AM
Sstrickstein's Avatar
Sstrickstein
I have a 2014 MCS. I had the same issue popping out of 1st gear. Upon looking on Google I came across a TSB on Mitchell online. BMW makes a new shifter tower with a stronger spring to keep the shifts in gear. Since my car was out of warranty I had to purchase the part which was about $190.00. The kit comes with a new set of screws and requires a special sealant for the operation. I followed the instructions and was done in about 20 minutes. The one month subscription to see the TSB was $19.95 but well worth it since I thought I had a bad transmission. All better now.
Old Dec 19, 2018 | 06:24 PM
kalphonso's Avatar
kalphonso
Excellent news. Service center stated similar remedy today (2018 Cooper Clubman S still in warranty) but decided to replace transmission just to be certain. I'll have to archive this solution in case this issue "pops up" (pun) again.
Old Oct 17, 2020 | 05:04 PM
Joebu78's Avatar
Joebu78
I know this is an older thread, but curious if others have still had issues. I have a 2019 JCW F54 All4. It had the exact same issues described and I am now on the third transmission. The car only has 24k miles and the second transmission started causing problems at 3k miles and was replaced at 4k.
I have been told by some Mini dealer folks (on the side, not sure if it's true) that there is a known issue with these transmissions and sometimes you get a "bad one." I feel like the shifts in the gates are inconsistent in the way they feel with the third transmission (and I've only got a few hundred miles on it). The reason this is concerning is it seemed to be how the other transmission failures started.
I'm shifting incredibly carefully now and have found that the shift feel is only improved if I first stomp the clutch to the floor, pause and then make a slow shift, which is gonna kill the clutch fast. I've driven only manuals for 20 years and have never had an issue like this. I also traded in my 2016 R60 All4 S for this vehicle and I'm regretting the trade.
Curious if there is more information on this and if there is anyone who could direct me to a after market transmission that might work better or if there's a way to know I'm getting the same bad transmission reinstalled over and over again...
Old Oct 17, 2020 | 06:26 PM
CPWillys's Avatar
CPWillys
Wow impressive, I sold my 2017 manual for an auto. Mine stayed the same until I sold it with 34k miles. I was really frustrated with the operation of that trans. There has to be an adjustment to the shifter linkage.
Old Oct 17, 2020 | 06:43 PM
kalphonso's Avatar
kalphonso
Thumbs up
The issue was completely resolved on both F54 Clubmans - one a Cooper S the other a JCW. Transmission was replaced only as a safety precaution. True issue had to do with the shifting mechanism.
Clubmans were repaired a Mini of Sterling, Sterling Virginia. Superb shop.
Old Oct 17, 2020 | 08:26 PM
J_L's Avatar
J_L
i haven’t been bothered by this before, but what you’re describing sounds like the way others describe the Clutch Delay Valve. There’s a thread somewhere here where the guy disabled it.
Old Oct 20, 2020 | 06:01 AM
Ray Oliver's Avatar
Ray Oliver
OP here, I just realized I never updated this thread.
My problem got worse to the point where second gear was unusable. I ended up having the transmission replaced under warranty.
My lease on my Clubman JCW expired a month ago. I miss the car a lot.
It's still available from my local dealer: https://minimoncton.com/en/shopping/...etail/2D66728A
Old Oct 20, 2020 | 03:17 PM
AirborneMini003's Avatar
AirborneMini003
My probably got worse to the point where second gear was unusable. I ended up having the transmission replaced under warranty.
Thats a beautiful car. It’s funny how many Canadian clubman owners on the forum there are. That has to be the only one in NB.
Old Oct 20, 2020 | 04:08 PM
Ray Oliver's Avatar
Ray Oliver
I've never seen another Clubman JCW around here but the dealer did have one in stock at one point. I'm quite certain that mine was one of a kind in Canada (BRG with Chili Red roof and stripes, manual, two tone interior). I picked it up as a demo in the GTA. Wasn't in the market for one but I couldn't say no to $11k off and 0.75% lease rate (with loyalty reduction).
Old Oct 20, 2020 | 05:12 PM
AirborneMini003
Oh Canada. Niche car in a niche market. Imagine if it didn’t move in Toronto how fast it will move in NB. That’s a great deal for what I think is a super desirable color combo and list of options. Some people think Christmas, I see Gucci. On paper, the residual probably made for a terrible buy back, and it will soon go for auction to a different market for a price you may have been tempted to keep it for...its a strange business. I bought mine with the depreciation of a Maserati, so it was great to pick up barely driven for pennies on the dollar.
Old Oct 20, 2020 | 07:23 PM
Ray Oliver's Avatar
Ray Oliver
The buy out price wasn't bad actually, $23k and change or so.
Old Oct 21, 2020 | 02:39 AM
AirborneMini003
That is very good. Especially if you put nothing down. Minis are not without their problems, but I’m not sure if you’ll find something more feature rich, practical and engaging to drive for the price.
Old Oct 21, 2020 | 05:24 AM
Ray Oliver's Avatar
Ray Oliver
Agreed, it was very tempting to keep it. But I like switching things up and we recently moved and don't drive nearly as much so I had already bought a own owner, meticulously maintained 2011 BMW 328i wagon, manual with sport package. A very rare combo. Also a great car to drive though definitely doesn't have the character of the JCW.
Old Oct 21, 2020 | 06:09 AM
AirborneMini003
I was shopping for the same thing when I picked up my clubman. The mini left more budget to personalize since the only 3 series wagon I found was Valencia orange with the m-performance package. It was beautiful, but hardly understated. Agreed that you found another unicorn in the 328. Drive it well!
