JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Is this a JCW Mini or not?
Old Dec 10, 2020 | 02:36 PM
  #451
A383Wing's Avatar
A383Wing
Originally Posted by Husky44
It's not that cold!!!
Fire up thst garage heater and get to work! 😁
I have to do some brake work on the black Charger first...plus fix a few other items, then it goes up for sale. The yellow Charger already has a new home in Missouri
Bryan
Old Dec 11, 2020 | 12:09 PM
  #452
A383Wing's Avatar
A383Wing
12/11/2020
After reading the service manual on how to remove the transmission via taking out the lower sub frame & components......I'm re-thinking about just pulling the entire engine & trans out the top together like last time.
Bryan
Old Dec 11, 2020 | 12:17 PM
  #453
Husky44's Avatar
Husky44
Originally Posted by A383Wing
12/11/2020
Bryan
FWIW, when I took mine to the indy shop that I use that has a lot of experience with first Gen MINIs, they said it was about the same either way, but they preferred, to pull the engine and trans together (they were working with a full shop, lift, etc). I don't think you can go wrong either way.
Old Dec 11, 2020 | 03:12 PM
  #454
A383Wing's Avatar
A383Wing
The manual says to get the car aligned after sub frame R&R....I really don't want to spend another $100 for a second alignment.....plus, I have already had the experience of pulling the drivetrain as a complete unit already....so there shouldn't be any surprises this time around. It will also save me the $$ in purchasing the engine holding bar
Bryan
Old Dec 15, 2020 | 01:18 PM
  #455
A383Wing's Avatar
A383Wing
Update 12/15/2020
Slowly gathering all the pieces for the transmission replacement this spring
Transmission is here from Allmag
I have new synthetic trans fluid along with a bottle of friction modifier for the LSD
New axle seals and rear main seal are on the way
17% pulley & belt should be here this week
I have not pulled the trigger on the Valeo clutch kit as of yet....still thinking about it
Bryan
Old Jan 9, 2021 | 06:09 PM
  #456
A383Wing's Avatar
A383Wing
Update 1/9/2021
The final pieces to the R52 JCW transmission swap arrived today.... I have to finish the brake work on the Charger first, then pull the Mini into the garage and start pulling the engine and transmission out of the car.... again
Bryan
Old Jan 9, 2021 | 06:49 PM
  #457
Husky44's Avatar
Husky44
What did you decide on for, the clutch?
Old Jan 9, 2021 | 07:07 PM
  #458
A383Wing's Avatar
A383Wing
I went with the single style flywheel, it's not the Valeo brand. I found it on Amazon for $275 for the complete kit. Single stage flywheel, clutch disc, pressure plate, throw out bearing, and new flywheel bolts and pressure plate bolt's.
Kit was sold and shipped from Megaparts company. I have dealt with them for a long time dealing with my Chargers in getting parts. Very reputable company.
I can get you the name of the clutch kit and number of the kit if anyone is interested
Bryan
Old Feb 20, 2021 | 12:45 PM
  #459
whitesilvermini's Avatar
whitesilvermini
Hey there Bryan,
I am clearing out a bunch of stored stuff in preparation for a move and came across an almost "mint condition" MCAW (Mini Cooper Automatic Window) circuit Rev 3a that I had used on my 2005 S.
Complete with printed installation instructions AND an auxiliary lead for using the garage door open feature! I have no idea if your JCW already has the ability to "one touch" the windows but seeing that I have no use for it and my last attempt to sell it on NAM did not get any takers it's yours... no charge... yes I said FREE!!!
If you are interested I can ship it down to you, I am up here in beautiful BC.. lol.
Let me know and should be able to get it off to you in the not too distant future, certainly before window down weather arrives.
Cheers,
Grampa
Old Feb 20, 2021 | 12:56 PM
  #460
A383Wing's Avatar
A383Wing
Originally Posted by whitesilvermini
Hey there Bryan,
Cheers,
Grampa
Thanks for thinking of me.....I sent you a private message
Bryan
Old Apr 5, 2021 | 01:21 PM
  #461
A383Wing's Avatar
A383Wing
Update: 4/5/2021
I think I have all the parts now to do the transmission swap in the little "Mini from Hell"....
Have the LSD transmission
Trans fluid
Single mass flywheel kit
17% SC pulley
Rear main seal and axle seals
On another note, rally lights are now installed
Bryan
Old May 2, 2021 | 01:06 PM
  #462
A383Wing's Avatar
A383Wing
Update 5/2/2021
Car is in the garage to start going under the knife again... need to replace the transmission with one from Allmag... pulling the engine and transmission together as a unit.
Also installing the 17% pulley on the supercharger while it's out
Bryan
Old May 6, 2021 | 03:04 PM
  #463
A383Wing's Avatar
A383Wing
Update: 5/6/2021
Engine and transmission are out, again... broken transmission is on the ground. Will install new rear main seal, Valeo style clutch, 17% SC pulley...... I hope I can remember how it all goes back together
Bryan
Old May 14, 2021 | 01:26 PM
  #464
A383Wing's Avatar
A383Wing
Update: 5/14/2021
Car is all back together and running again. New Valeo style clutch with single mass flywheel, 17% pulley and new belt
I have not had a chance to take it out and drive it hard to see how it does with the new pulley, but I think from what little I have driven it, I'm going to like it. The clutch feels great, grabs good and firm, no excess noise either.
Bryan
Old Aug 18, 2021 | 10:53 PM
  #465
A383Wing's Avatar
A383Wing
Update: 8-18-2021
The little R52 is still working well, knock on wood.... haven't driven it as much lately, life has gotten in the way.
I did get the LED corner lights installed, they look great. Also found out that all my windows go down at once when I push the "window down" button on the window header. I have an "up" module here, not sure if I'm going to install it though.
Pictures of corner lights below
Bryan
Old Aug 19, 2021 | 07:22 AM
  #466
Husky44's Avatar
Husky44
Looks good!
Haven't been doing much but driving mine either. Lots of work on the Mustang this summer. I need to do an alignment and tune, then it's drivable.
Old Aug 28, 2021 | 03:55 PM
  #467
ItsmeWayne's Avatar
ItsmeWayne
Hi Bryan,
I am glad to see you got the R52 going down the road again!
Old Aug 28, 2021 | 05:11 PM
  #468
A383Wing's Avatar
A383Wing
Originally Posted by ItsmeWayne
Hi Bryan,
It's been a long ride on this car....I sold the R53, so this convertible is the only Mini I have....hope things are going well for you
Bryan
Old Sep 4, 2021 | 04:42 PM
  #469
A383Wing's Avatar
A383Wing
Update: 9-4-2021
I think the ignition switch is going out on the car....sometimes it will not turn over, and sometimes the NAV screen will not turn on. At times, the convertible top will not open as well unless I turn the key back and forth a few times.....sounds like the contacts inside the switch are failing....
New switch is anywhere from $25 up to $100, depending on where I am looking at the time....
Bryan (just another thing to fix)
Old Sep 4, 2021 | 05:04 PM
  #470
Husky44's Avatar
Husky44
Update: 9-4-2021
You didn't think you were done, did you? 🤣
Making any progress on the Charger?
Old Sep 5, 2021 | 08:51 PM
  #471
A383Wing's Avatar
A383Wing
Guess I am not done....I figured that I have repaired or replaced most everything else....oh well...new ignition switch is $35 with a lifetime warranty....just not sure if it's the car's lifetime, or mine...LOL
The brakes and other items on the black Charger are done....all it needs now is a clutch disc....I will leave that to the next owner
I will update this thread when the new ignition switch is in
Bryan
Old Sep 5, 2021 | 09:26 PM
  #472
Husky44's Avatar
Husky44
Bryan
Black? Why do I have purple in my head?
I was asking about your wing car, but also remember that you have more than 1 Charger.
Sounds like you're selling? Hopefully not the wing car.
Old Sep 6, 2021 | 05:57 PM
  #473
DFTR's Avatar
DFTR
Hi Bryon, hope all is well. Could you describe your experience with the 17% pulley? Good and bad?
thanks,
John 2006 R52 JCW Miss Girl.
I
Old Sep 29, 2021 | 03:26 PM
  #474
ItsmeWayne's Avatar
ItsmeWayne
Update: 9-4-2021
Hey Bryan, Were you able to get this sorted out yet?
I still have not figured out why my fob will no longer do anything anymore. I hope I can get this sorted out at some point! It bums me out! It is not the mirror. Maybe the ignition switch, Just have no idea at this time,
Itsme Wayne
Old Sep 29, 2021 | 03:42 PM
  #475
A383Wing's Avatar
A383Wing
Itsme Wayne
Wayne....I did get the new ignition switch in.....so far, it's cranked over every time, and the NAV screen has turned on every time.....have not checked the convertible top issue yet....been raining most every day here, which we really needed. I'm fairly certain the issue with my fey fob is in the mirror, I know my key is sending a signal, at least that's what the dealer told me. I'm not buying a $750 mirror from overseas
Bryan
