JCW Stabilization Control
Old Jan 22, 2018 | 10:04 AM
KYDan's Avatar
KYDan
I posted this question on the mini 56 forum, but no one has answered, but there has been a lot of interest, so I thought I would try this forum as well as the F56 hatch forum.
1. ELECTRONIC DIFFERENTIAL LOCK CONTROL
Lock control (EDLC). If you’re a confident driver, and want full engine power with near-complete control, you can switch off DSC and DTC. But MINI still keeps you safe. EDLC kicks in when needed, to prevent slip and stop wheel-spin during aggressive cornering and acceleration.
2. DYNAMIC STABILITY CONTROL
Stability Control (DSC). DSC is proven to reduce accidents. Intelligent sensors detect if you’re veering even slightly off course. DSC then activates to adjust the engine torque, and applies brake force to individual wheels where needed. You’re in safe hands.
3. DYNAMIC TRACTION CONTROL
Traction Control (DTC). DTC provides the best possible driving force on every surface, even slick or sandy ones. It also restores power to the engine sooner than DSC, and lets the car slide a bit before correcting its course, which is kind of fun if you’re into your driving thrills.
However, there is only one switch regarding traction control. Unless, there is one that I am not aware of. Am I missing something? I thought I knew all this, but obviously not!
Old Jan 22, 2018 | 01:44 PM
2017JCWerks's Avatar
2017JCWerks
Press the switch once and DTC is gone. Press and hold the switch for (not sure how long, until the message changes) and the DSC goes away. No DTC gives the burnouts. DSC helps you turn without wheel spin. I felt the car was faster with DTC and DSC off on the autox track this weekend.
Old Jan 22, 2018 | 02:11 PM
KYDan's Avatar
KYDan
Thanks, from what I have gleaned from several other answers (I posted on several sites.) You hold the switch down for at least 3 seconds, but not longer than 10. I have not tried it with the ELDC option. I mostly do twisties, but occasionally track.
Old Jan 23, 2018 | 01:43 PM
TheBigNewt's Avatar
TheBigNewt
Hold switch down 3 seconds and some little light comes on on the center display somewhere. The guy who did my ECU tune said he raced a G2 Mini (autoX I think) with the DTC on and went through a whole set of rear brakes over several days because that system uses them a lot.
Old Jan 23, 2018 | 06:31 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
DTC or DSC?
DTC should reduce how much the computer tells the car to brake. DSC should apply more brake between the 2
Old Jan 24, 2018 | 03:49 PM
siriuszero's Avatar
siriuszero
DSC (default on power on - all safety systems on) --> DTC (quickly press DSC OFF switch. Prioritizes forward motion instead of stability. Will let wheel spin a bit more) --> EDLC (Press and hold DSC OFF switch. All stability and traction systems turned off including corner brake control, rev matching (M/Ts), auto up/down shifts (A/Ts). Won't turn off ABS. Works like an electronic limited slip.
Old Jan 24, 2018 | 04:11 PM
KYDan's Avatar
KYDan
Thanks, yours is the first post that defines what actually remains when go to EDLC mode!
Old Jan 24, 2018 | 07:18 PM
BitsForBrains's Avatar
BitsForBrains
Im a bit confused. My F56 clearly says "Dynamic Traction control Activated" when I hit my switch. The car slipping icon illuminates with "off". It does mention something about more traction control but less stability control. So when I hit the switch it seems to me that DTC is getting turned on, not off. If I hold the switch then it indicates that DSC is turned off, which makes sense.
Old Jan 25, 2018 | 05:50 AM
KYDan's Avatar
KYDan
The default setting is DSC, when you turn that off it enters DTC, and when you hold the switch down for 3-10 seconds it turns both off and you are in ELDC mode. These modes are numbered in my original post. I was pretty confused by this at first as well.
Old Jan 25, 2018 | 05:52 AM
Mini_Vinnie
Moderator
Correct, DSC is always on, you shut it off with the switch, activating DTC which gives more traction but lose stability. Thats the little yellow light you see
Old Jan 25, 2018 | 06:30 AM
02fanatic's Avatar
02fanatic
These threads on here and the f56 forum are a huge help. I have never really understood these settings, as reading the manual is shamefully inadequate & confusing! Maybe it’s just me but it wasn’t very easy to understand...and does the manual even mention the ELDC mode? Hmmmmm.The JCW Team races at Daytona tomorrow! Go JCW’s!!!
Old Jan 25, 2018 | 08:23 AM
Mini_Vinnie
Moderator
Heck yeah, that's whats great about this place!
Old Feb 6, 2018 | 07:03 AM
Johnnycash's Avatar
Johnnycash
Just a question : I plan to track my JCW, it is a manual.
Is there any way to put everything off except the rev matching?
This is really something interesting on track!
Old Feb 6, 2018 | 07:38 AM
Mini_Vinnie
Moderator
So your best bet would be to hold the toggle switch for 3 secs, shutting off DSC and DTC. This is usually what I do in the non-winter months on dry roads.
Old Feb 6, 2018 | 07:41 AM
Johnnycash's Avatar
Johnnycash
so basically the car will be in ELDC? Which means no rev matching :(
Old Feb 6, 2018 | 10:00 AM
Mini_Vinnie
Moderator
Thats a great question. I never noticed if rev matching was deactivated or not. Its dry here so I will try it on my way home
Old Jul 2, 2018 | 08:21 AM
CarFreak427's Avatar
CarFreak427
When DSC is deactivated, it does indeed also turn off rev-matching.
Old Jul 2, 2018 | 08:22 AM
Mini_Vinnie
Moderator
Funny, I never realized that
Old Jul 2, 2018 | 08:35 AM
stardust88's Avatar
stardust88
nice information in here ...
Old Jul 2, 2018 | 09:45 AM
elsnaibs's Avatar
elsnaibs
All driver aids are turned off, including rev matching and hill assist.
Old Jul 5, 2018 | 09:49 AM
Clutch Wotan's Avatar
Clutch Wotan
without LSD cornering fast with a MINI is impossible.
Old Jul 5, 2018 | 09:59 AM
elsnaibs's Avatar
elsnaibs
Mine has EDLC, but not an actual LSD, and corners very fast. Eventually I will probably get a Quaife later on if I feel like it's neeeded, but the car has so much mechanical grip with the current setup, it's not a "must have".
Old Jul 5, 2018 | 10:56 AM
SFMCS's Avatar
SFMCS
I asked at the MINI Motoring School and they run 50%DSC on the racetrack and auto cross (could have fooled me as the tire squealing) and 100% or 0 on the wet skid pad to show the difference.
Old Aug 1, 2018 | 06:32 PM
rtowell's Avatar
rtowell
Despite all of this wisdom, I learned that as soon as you activate cruise control everything goes back to the default settings. After driving almost 8,800 miles, to include MTTS West, the only weakness in the car involved passing other cars on wet, uneven, different surfaces. Under those conditions, the traction control gets very active and can make things really dicey at high speeds ... possibly a real LSD is in the works before next time.
6speedDriver
Apr 12, 2017 01:16 PM
John S
Jan 7, 2017 06:54 PM
jsnake77
Nov 22, 2010 06:58 PM
fishbulb
Jun 19, 2009 07:42 PM
xizor
Dec 10, 2006 08:13 AM
