JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW New to me JCW
Old Dec 23, 2017 | 10:11 AM
Skidude's Avatar
Skidude
New to me JCW
After giving up my ‘09 base to my daughter when she turned 16 I bought myself a replacement. A bit of a gamble, but I bought a 2011 JCW with the N14. Its in great shape with excellent maintenance records.
Old Dec 23, 2017 | 10:16 AM
cornjuice's Avatar
cornjuice
Congrats on the purchase! Make sure to check your VIN, to see if it's a MCS with kit, or a factory JCW. Helps a bit when you start looking for parts to add/swap/replace.
Old Dec 23, 2017 | 10:50 AM
Skidude's Avatar
Skidude
I ran the VIN and it’s authentic JCW.
Old Dec 23, 2017 | 01:58 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Congrats it looks great
Old Jan 1, 2018 | 02:32 PM
bugeye1031's Avatar
bugeye1031
Moderator
Nice JCW - great color combination! What do you notice the most converting from the base?
Old Jan 1, 2018 | 03:12 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Great looking replacement.
Old Jan 1, 2018 | 07:12 PM
Skidude's Avatar
Skidude
Very Different
A whole different car, well mostly. The base I gave my daughter was an automatic. The JCW is a six speed manual. I usually drive in sport mode all the time, I like the pops and burble. It has an aftermarket exhaust but I don’t know which one. The differences in driving are as follows:
1. It sounds much different
2. Shifting vs auto, I like the manual
3. It’s faster, much faster
4. The speedo is only off by 3mph instead of 5 in the base
5. A little bit of torque steer up around 5g
6. It doesn’t rattle as much as the base ‘09
That’s all for now. I’ve not has the chance to really test out the suspension. Looking forward to taking it up in the mountains.
Old Jan 5, 2018 | 03:19 PM
3lusive's Avatar
3lusive
Welcome to the jcw club point 4 is interesting, I always thought the speedo correction was a percentage of the speed (~5%), not a constant number difference. Maybe due to the different size tires you see the difference in speed correction. Around 80 more hp than the base, I bet it feels way faster!!
Old Jan 5, 2018 | 05:05 PM
Skidude's Avatar
Skidude
Thanks. What I find really interesting about the speedo is that it is accurate at about 25 mph and under. At 30, about 2 mph off, at 35 about 3 off, at 40 and above 5 off. (Speedo is faster than actual). This is on the base, I’ve not checked the JCW that closely yet. I’ve been using a gps for checking so that may no be exactly accurate either.
Old Jan 6, 2018 | 06:51 AM
Whine not Walnuts
My speedo is off as well, about 2 mph high around 35 and about 4 at 65.
On the mountains, a friend and I are always trying to get some Day Runs as we can hit some good twisites in about 2 1/2 hours. Mount Airy, NC is good starting off point and I have even thought about spending a night up in Marion Va. so that both the Back of Dragon and the Snake can be hit on Day 2.
Old Jan 6, 2018 | 07:33 AM
bugeye1031's Avatar
bugeye1031
Moderator
I had my digital speedo re-coded to be closer to accurate - and it matches my GPS speedo pretty well. As far as I know, there isn't anything you can do to fix the analog speedo other than change tire size.
Old Jan 6, 2018 | 06:07 PM
dube53's Avatar
dube53
The truth is there is really nothing to compare even between a base and S and furthermore a JCW.
The only thing they have in common in HT configuration is excessive body flex and as you said...... rattles.
I don't care about the speedo accuracy as I care much more about the JCW power and torque, brakes, suspension and handling and frame dynamics/ body stiffness of the Coupe as far as I am concerned.
I drive on mountain roads most of the time and yes, I could not even think I would have to go through the pain of an A/T shifting all the time from a so small engine when driving fast.
Snaps
Tires, Wheels, & Brakes
Jul 29, 2008 09:42 AM
goonerfan
Sep 22, 2007 08:58 PM
CDMINI
Oct 4, 2006 11:49 PM
Nondual
Oct 1, 2006 08:53 PM
hexproject
Mar 24, 2006 08:42 PM
