JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW O2 sensor fault P0141 still
Old Nov 29, 2016 | 08:25 AM
J Free's Avatar
J Free
I had P2270/P0137/P0141 faults on previously. I replaced turbo with a frankenturbo (not because of faults of course, but other issues). I was hoping this would make the faults go away too. The P0141 kept coming back so I replaced the O2 sensor with a Bosch unit (lower sensor) Now every 4-5 days the fault will come back. Any thoughts?
Old Apr 15, 2017 | 08:00 AM
J Free's Avatar
J Free
Still problems-I just replaced the O2 sensor again and the light still comes on. Any ideas?
Old Apr 29, 2017 | 12:41 PM
sikamini's Avatar
sikamini
Did you replace both O2 sensors?
Old Apr 29, 2017 | 06:56 PM
J Free's Avatar
J Free
No, I only got an an error code for the lower one.
Old Apr 29, 2017 | 07:01 PM
sikamini's Avatar
sikamini
I usually replace both at the same time regardless of which gets the code.
Old Apr 30, 2017 | 08:15 PM
J Free's Avatar
J Free
Seems like a big investment to roll the dice on. Did you have the same situation?
Old May 24, 2017 | 02:22 PM
sikamini's Avatar
sikamini
I usually do both when one O2 goes thinking the other can't be far behind.
Old Jun 1, 2017 | 08:06 AM
J Free's Avatar
J Free
Frustrated-looks like the options are:
1 Replace upstream sensor with similar Bosch (going on the suggestion the it could effect the new one)
2 Replace original one with dealer oem item-what the dealer would do first, assuming the aftermarket was bogus (if it doesn't fix I'm out the bucks)
3 Have dealer replace with oem
thoughts?
