JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Transmission Grind / Popping out 4th and 6th
Old Aug 14, 2016 | 10:48 AM
Black Sharpie's Avatar
Black Sharpie
I am getting a slight grind and sometimes a gear pop out if it doesn't make it all the way into gear. This is both in 4th and 6th.
Car has 46K on it. 2012 R58.
What could be causing this? I am thinking about changing the tranny fluid as something easy to see if it helps. What are the best fluids?
Is there anything coincidental about it being both 4th and 6th gear since they are on the same side?
Am I going to need a new clutch/transmission soon?
Old Aug 14, 2016 | 06:11 PM
dube53's Avatar
dube53
At 46K, it is strange your gearbox fails. I never read anything about that.
Old Aug 14, 2016 | 07:16 PM
oldbrokenwind's Avatar
oldbrokenwind
There's linkage on top of the tranny with bushings that wear out. 4th & 6th use the same bushing. Not the easiest to get at, but not difficult either.
Old Aug 14, 2016 | 07:50 PM
dube53's Avatar
dube53
If bushings wear so fast, this is not looking good.
But.... I believe this is just abuse and will never be covered by the warranty.
Old Aug 15, 2016 | 07:30 AM
Black Sharpie
I drive it hard but never have ground a gear or money shifted. Unfortunately I am out of warranty by 4 months not by miles. I'll have to find a document to check this linkage out.
Old Aug 15, 2016 | 08:42 AM
3lusive's Avatar
3lusive
I did a manual transmission fluid replacement with Redline MTL and had no problems. I think you need two bottles totaling 2 quarts and it helps to get a fluid pump, there's one recommended on amazon when you look at the redline mtl and it works great, just doesn't screw on to the head of the bottle.
Old Aug 15, 2016 | 08:44 AM
Black Sharpie
Thanks! So you put redline MTL in your JCW tranny? I was trying to poke around the forum to find the right redline.
Seems some do MTL and some put in the 75W90 LT4
Old Aug 15, 2016 | 10:08 AM
3lusive's Avatar
3lusive
I put the MTL in my 08 S transmission, but I don't see why it wouldn't work with the JCW one as well. I think you'd be safe to use either but here's a thread i found that sort of explains the differences between MTL and MT-90. From what I can tell there's not much besides viscosity.
http://www.xwebforums.org/showthread.php?t=4329
Old Aug 15, 2016 | 12:49 PM
Black Sharpie
Thanks 3lusive! Great info there. Will try and get some into the tranny this weekend and see how she feels.
Also looking to check the linkages but I cant find a guide just yet. I am going to scope out the R56 threads shortly.
liliB
May 23, 2016 04:07 PM
Big_Mike
May 2, 2016 09:30 AM
cadfael_tex
Apr 15, 2016 07:40 AM
mmmark
Nov 6, 2005 07:03 PM
Azwed
Oct 12, 2002 10:45 AM
