JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Installed NM Engineering short shifter adapter
Old Aug 25, 2015 | 10:26 PM
minimofo's Avatar
minimofo
Installed the NME short shifter adapter today along with NME shifter cover. I was able to do it without removing the exhaust. It takes a bit of wiggling of the tunnel heat shield...after removing the rear exhaust hangers and the middle tunnel brace below the center section of the exhaust pipe. Once the heat shield came out, the hardest part was removing the stock shifter cover. Installing the NME short shifter adapter itself was very easy, and the new NME cover with deeper tray section was just a snap into place.
All I can say is wow! NME states it's about 20% reduction in shifter travel, but I can attest that it's more like 40% reduction. Excellent mid for more smiles...shifter now feels like my favorite metal on metal click click and such short travels!
Old Aug 27, 2015 | 02:48 PM
Minitauro's Avatar
Minitauro
Nice - seems line NME is putting out some quality stuff.
Old Aug 27, 2015 | 04:32 PM
minimofo's Avatar
minimofo
Yes, ALL products I've bought from NME have been top quality and top customer support even when I ask silly questions. I highly recommend them. All their products are made in the U.S. if that matters to you.
Old Aug 28, 2015 | 01:09 PM
sgscomps's Avatar
sgscomps
Everything I have purchased from NM is excellent quality. I also installed the short shifter and really like the results. I agree it feels like way more than 20%
Old Aug 28, 2015 | 01:51 PM
Grizld700's Avatar
Grizld700
I've had mine for almost 2 years and couldn't be happier
Old Sep 8, 2015 | 08:33 AM
minimofo's Avatar
minimofo
It was PITA to pry off the stock shifter ball for some reason. I had to use a crow bar to pop it off. Putting the NME one on was a piece of cake with a little bit of grease applied. The stock hard plastic cover was also a ***** since I didn't have a good pick tool to get at the side tabs. I ended up just breaking it off since I had the new modified NME cover anyway.
Old Nov 5, 2015 | 02:57 AM
malibujoey's Avatar
malibujoey
hahaha easy for you because you have a lift. I'll drive up to Ohio and you can put mine in ****. Great pics as usual. Thanks!
Old Nov 5, 2015 | 08:40 AM
Yea, with a lift and skill it can be done. Its a tight fit around the exhaust tunnel. If you have a split tool or the cable tool for the front , its easy. 83300494345
https://www.ecstuning.com/Search/SiteSearch/83300494345/
squawSkiBum
Oct 2, 2015 09:21 AM
flredmini
Sep 3, 2015 07:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
