JCW JCW Aftermarket Wheels
Old 01-06-2022, 09:25 PM
Bruce R's Avatar
Bruce R
Bruce R is offline
Question for the people who put new wheels on their cars--What TPMS sensors did you get? OEM or aftermarket? Any recommendations? I see OEM ones are around $65 each, but you can buy 4 for half that amount if you go aftermarket. If you bought cheap ones, have you had any issues with functionality or early failure/dead batteries?
  #602
Old 01-07-2022, 07:28 AM
TheGeekGuy's Avatar
TheGeekGuy
TheGeekGuy is offline
$65? I suppose it is where you buy them but I've seen average costs around $350 for a set of four OEM, MINI sensors. I have a set purchased with my wheels from NEUSpeed. They are fine, but don't have a temp sensor so if have BIMMERCODED that feature "on" in your car they won't work.
Bruce R (01-07-2022)
  #603
Old 01-07-2022, 09:45 AM
rtowell's Avatar
rtowell
rtowell is offline
I just swapped my OM sensors onto the new wheels. Worked fine.
  #604
Old 09-09-2022, 05:51 AM
rmepilot's Avatar
rmepilot
rmepilot is offline
New shoes for the wife's F54.
BBS XR 8x18 ET37
The following 3 users liked this post by rmepilot:
///Matthew (09-09-2022), dbturbo2 (09-09-2022), ECSTuning (01-05-2023)
  #605
Old 09-09-2022, 12:36 PM
ECSTuning is offline
Received 1,966 Likes on 1,766 Posts
Nice BBS
  #606
Old 09-09-2022, 07:57 PM
rmepilot's Avatar
rmepilot
rmepilot is offline
Nice BBS
Thanks.
I still owe you pics of the Eventuri intake. The last pic shows the scoop installed.
ECSTuning (03-31-2023)
  #607
Old 09-13-2022, 07:08 AM
Cant wait to see.
  #608
Old 09-19-2022, 11:57 AM
benben01's Avatar
benben01
benben01 is offline
Posted these in the GP group.. Figured I share them where as well.
Enkei GTC02 18x8.5 +31 (org +43 then added 12mm spacers to clear) running 245/40/18. Got them as a combo from a VM member. Very minor rubbing in the rear around the "carpet" liner under full compression. A set of 245/35/18 tires should remedy that when the 245/40 are worn.
  #609
Old 09-19-2022, 01:12 PM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
Darbys2019MiniJCW is offline
I have some TrakLite 18x8.5 Wheels with 255/35/18 Race Tires and 15mm Spacers for AutoXing. I did add some Aesthetic Flairs (Did not fit but with work got them to fit)...no rubbing!
Actually gonna probably either jump to some 18x9 Wheels for some 265/35/18 Tires...
The following 6 users liked this post by Darbys2019MiniJCW:
benben01 (09-19-2022), boki (03-13-2024), ironhead3fan (09-30-2022), jpreston (03-25-2024), Mini-Titan (03-11-2024), Speedy-218 (09-20-2022) and 1 others liked this post. (Show less...)
  #610
Old 09-19-2022, 01:28 PM
benben01's Avatar
benben01
benben01 is offline
Which model TrakLite wheels do you have?
  #611
Old 01-04-2023, 04:24 PM
SoCalledFriend's Avatar
SoCalledFriend
SoCalledFriend is offline
Originally Posted by SimpleMini
Another clearer view of the colour combo
BBS LM 18" 8J ET45, clears the JCW Brakes (just) and running on 215/40/18 Bridgestone Re-71RS.
Man.....this is CLEAN!
When you say these wheels "just" clear the brakes, how many MM are we talking?
I can't seem to find these wheels in this configuration anywhere. Is there a part number for these I could reference?
Appreciate the help!
The following 2 users liked this post by SoCalledFriend:
benben01 (01-04-2023), ECSTuning (01-05-2023)
  #612
Old 01-05-2023, 08:35 AM
F56-JCDub's Avatar
F56-JCDub
F56-JCDub is offline
Those are the LM430 part which is listed on the BBS Japan website under the 18" tab: https://bbs-japan.co.jp/en/products/1142/
TYPE SIZE INSET H/P.C.D
LM430 18×8.0 45 5/112.0
The following 2 users liked this post by F56-JCDub:
ECSTuning (01-05-2023), SoCalledFriend (01-10-2023)
  #613
Old 03-26-2023, 06:22 PM
Trakwagn's Avatar
Trakwagn
Trakwagn is offline
Just got my new wheels sorted, they needed a bit more work to get the fitment right then I expected but I think the end result was worth it.
18x8.5" +43 König Ampliforms
225/40r18 Continental DWS 06 Plus tires front and rear
10mm spacer in the front, no spacer in the rear
Silver project camber plates to add 1.5 degrees of additional camber up front so they don't poke out from under the fenders
The car is lowered on NM springs
No rubbing on this set up and it clears the front caliper by about 2.5mm.
The following 6 users liked this post by Trakwagn:
ECSTuning (03-31-2023), laurengrey (06-05-2023), renchjeep (04-01-2023), rmepilot (03-26-2023), Speedy-218 (03-28-2023), Tngo23 (05-12-2023) and 1 others liked this post. (Show less...)
  #614
Old 03-29-2023, 07:00 PM
shimwrecker's Avatar
shimwrecker
shimwrecker is offline
The above car is sexy
The following 2 users liked this post by shimwrecker:
ECSTuning (03-31-2023), Trakwagn (03-29-2023)
  #615
Old 03-09-2024, 04:10 PM
E. Holder's Avatar
E. Holder
E. Holder is offline
So no other alterations were needed? Just spacers? Just verifying. Having a hell of a time finding rims that fit.lol
Originally Posted by bluonyx
Enkei TS-10's 18x8
General G-MAX AS-05 215/40R18
Also upgraded the brakes to slotted/cross drilled and ceramic pads. No more brake dust!
Attachment 192046
Attachment 192047
Attachment 192048
  #616
Old 03-10-2024, 07:18 AM
E. Holder's Avatar
E. Holder
Where did you get those flares? Did you need to cut down any metal for wheel clearance?
phantasms
Wheels/Tires/Brakes
03-29-2018 10:22 AM
Blues Trucker
02-09-2016 02:14 PM
k_h_d
Tires, Wheels, & Brakes
08-22-2012 07:35 PM
minimini482
01-20-2010 08:53 AM
Kellzir
02-06-2005 03:41 PM
Quick Reply: JCW JCW Aftermarket Wheels
