JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Just picked up a 2004 w/ JCW kit
Old Jan 6, 2015 | 11:06 AM
DRMCDAVE's Avatar
DRMCDAVE
I just picked up a 2004 with JCW kit, aero kit, etc as a toy/DD. I've always wanted one and while driving through town I came across a nicely outfitted 2004 PW. Obviously The gearing, LSD, and 05+ headlights are all wants but hardly needs for my use, not for now anyway.
A little back story on myself. I've owned a few e30's, e36's, and still have one of each. e30 325ix and a 2000 BMW Mcoupe e36/7 if you're into codes.
The MINI has 111k on the clock so it's probably due up for some maintenance. I know the previous owner personally. He's both mechanically inclined and seems to maintain his stuff but he's not an enthusiast of any kind. The brakes were just done, new alternator, and I believe he said the steering pump was done.
Should anything be on my immediate list of maintenance items? Any recommended upgrades. It rides pretty rough on the JCW suspension and sits low enough for where I live. I suppose it's possible that the struts are toast but it seems to handle pretty well (especially for sitting on snows at the moment).
Attached Thumbnails Just picked up a 2004 w/ JCW kit-mini.jpg
Old Jan 6, 2015 | 02:24 PM
JABowders's Avatar
JABowders
Veteran: Army
Welcome to be MINIacs... Sounds like a sweet ride.
Motor on!
Old Jan 6, 2015 | 04:03 PM
bavmotors's Avatar
bavmotors
Hate to do it but let's see that m coupe. Congrats of the mini both fun cars.
Old Jan 6, 2015 | 08:35 PM
808keith's Avatar
808keith
Nice find. Here's what I would probably check as well to name a few:
-belt
-tensioner
-cabin filter
-oil change
Old Jan 10, 2015 | 09:52 PM
00Mini's Avatar
00Mini
The harmonic balancer failing can ruin your day very quickly so keeping an eye on it or replacing it can be most beneficial.
Old Jan 11, 2015 | 08:52 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Welcome looks good.
Old Jan 11, 2015 | 09:35 AM
DRMCDAVE's Avatar
DRMCDAVE
Here is the Mcoupe and the 325ix.
I'll look into those items. I may just have to put a list together and do an big order.
Does anyone know someone that is well versed in MINI's near Gettysburg, PA?
Attached Thumbnails Just picked up a 2004 w/ JCW kit-img_6245.jpg   Just picked up a 2004 w/ JCW kit-img_1033.jpg
Old Jan 11, 2015 | 10:21 AM
bavmotors's Avatar
bavmotors
Originally Posted by DRMCDAVE
Here is the Mcoupe and the 325ix. I'll look into those items. I may just have to put a list together and do an big order. Does anyone know someone that is well versed in MINI's near Gettysburg, PA?
you have some fun cars, those e30 325xi are hard to find.
Old Jan 15, 2015 | 05:20 AM
DRMCDAVE's Avatar
DRMCDAVE
The originals was 325ix not sure why they changed it to 325xi. Nevertheless it's a cool car but pretty old now. I rarely drive it but I can't bring myself to sell it. It just has that cool 80/90's look to it. If e30 M3 weren't going into the stratosphere pricing wise I'd try to find one but decent ones are selling in the low to mid 20's now.
Old Jan 15, 2015 | 06:51 AM
JABowders's Avatar
JABowders
Veteran: Army
PM sent
Motor on!
Old Jan 25, 2015 | 07:14 PM
Stinch's Avatar
Stinch
DRMCDAVE
Your Mini sounds a lot like my 2004 MSC/JCW with 121k miles that I bought this past December. After reading this forum, I've since changed the oil in the s/c, crank sensor o-ring, thermostat and housing, and the oil pan gasket. Really got to know the front of my car after that. Did find the upper radiator hose had rubbed thin in one spot so I replaced that. Would have never found the hose issue if I hadn't gone as far as I did.
That is a big plus if your power steering pump was replaced along with the fan. Mine has not been replaced yet and is covered in oil from the hoses. My control arm bushings are cracked and will get replaced in the spring along with the pump and hoses. Belt tensioner from Amazon and replacing the crank pulley with a ATI unit is soon to follow.
Good luck with your MCS and have fun.
Rich
Old Jan 26, 2015 | 06:36 AM
DRMCDAVE's Avatar
DRMCDAVE
Originally Posted by Stinch
DRMCDAVE
Rich
Those are good recommendations. I think I'm going to start with a suspension overhaul and then go from there.
Old Feb 9, 2015 | 09:43 AM
CoolioMcPimp's Avatar
CoolioMcPimp
Looks clean! Aftermarket bumper too? If you haven't done the in warranty power steering pump / fan replacement just be aware that it can over heat and fail (They won't replace it until it does and it has been noted to fail more than once.) Bushings of all kinds are known to go (Control Arm and Sway Bar mostly). Watch electronics and make sure they all function normally (some reported ECU Problems.) Keep an ear out for any grinding sounds from the Super Charger as well as timing chain rattle. Charger can dry out inside from loss or use of S/C oil. Some folks have done clutch depending on how hard it was driven.
Upgrades... People go with poly bushings to tighten it up a little. An Air intake mod usually happens, but the JCW air box is pretty good so maybe a filter. Some people do the diagonal Cabrio braces and strut bar. Cat backs sound good. People lower them, but personally the Cooper is far low enough for me. A lot of people do the Aux input retrofit for the stock radio (ECS Tuning). Carbon fiber add-ons are common. Rims if you want, some of the stock rims are boring. Though yours look pretty good. Some people have done the Oil plug drain valve to make Oil Changes easier. GET RID of run flat tires. Super charger pulley mod 15% - 17% seems really common.
I'd imagine you've done your research haha. You seem really into your cars! Good choice overall. I imagine the price tag isn't bad now KBB price dropped 3k on my 2005 MCS R53 since I bought it in April :( .
Feel free to contact me directly if you have more questions. I don't have a lot of the mods cause I'm broke, but I think I could give some helpful tips / advice.
Old Feb 9, 2015 | 03:15 PM
DRMCDAVE's Avatar
DRMCDAVE
I like the JCW intake and exhuast. This is my DD so they are fine. I do have a set of 18 inch OZ superleggeras that came with the car. I'm going to get some Michelin Pilot SS for those once the weather improves.
I was thinking about refreshing the bushings, and doing the rear sway bar and camber plates after the winter.
The other thing I really want are facelift headlights and a LSD both are which are pretty costly.
I'm a fan of an OEM+ type cars especially for a DD so I'll try to keep it classy.
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
PrimePower
Aug 11, 2015 12:51 PM
SDMini_me
Aug 7, 2015 08:10 AM
