JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Jcw's Head?
Old Jan 3, 2011 | 08:26 AM
redboy23's Avatar
redboy23
Jcw's Head?
What are the porting specs on the JCW head?
Old Jan 3, 2011 | 08:45 AM
Vollgas's Avatar
Vollgas
What do you mean "porting specs"?
Old Jan 3, 2011 | 09:03 AM
ZippyNH's Avatar
ZippyNH
lol...not much!! It is CNC machined, but I have never heard of the exact #'s....
Exaust ports only I think...
Virtually ANY aftermarket ported head (WMW, RMW, Thumper, etc) will make a lot more hp. As a factory option it was a good way to get HP, and matain the warrenty, but the other aftermarket options are all much more cost effective per HP of gain.
Old Jan 3, 2011 | 09:09 AM
redboy23's Avatar
redboy23
Sorry, let me rephrase. Would I be able to mod a MCS Head to match a JCW specs?
Old Jan 3, 2011 | 09:33 AM
jaridp's Avatar
jaridp
There isn't really much done to the JCW head other than a mild port on the exhaust side. I have never seen the specs listed but if you are thinking of porting your head I would recommend contacting one of the companies listed above and get MORE than just the JCW porting done.
Old Jan 3, 2011 | 09:40 AM
Vollgas's Avatar
Vollgas
The porting for JCW head was only on exhaust side.
It was very little done.
Any R53 head can be ported out to a much higher performance level than JCW spec.
Old Jan 4, 2011 | 09:48 AM
redboy23's Avatar
redboy23
Ok then. Guess I should find out what would be good for daily driver.
Old Jan 4, 2011 | 04:39 PM
JCWSLAYER's Avatar
JCWSLAYER
If your not looking to spend a ton of money do a CAI, 15% pulley and drop in a NS1 cam those few mods will totally bring your stock MCS to life.
Old Feb 9, 2011 | 10:35 AM
redboy23's Avatar
redboy23
Sweet! 15 % pulley and CAI are installed already, so cam would give this baby a boost.
Old Feb 9, 2011 | 01:08 PM
HRM's Avatar
HRM
Then sign up here...
Cam + tune FTW!!
https://www.northamericanmotoring.co...ut-2011-a.html
Old Feb 15, 2011 | 09:23 AM
JumpingJackFlash's Avatar
JumpingJackFlash
The exhaust ports on the JCW head are enlarged by 4mm. That's it.
Old Mar 3, 2011 | 09:55 AM
redboy23's Avatar
redboy23
My baby is back on the road again, and more spunky too. I changed all the parts recommened when doing a head gasket. It turns out the head wasn't cracked. NAM is my new home now. Thanks for the help guys.
Old Mar 3, 2011 | 10:00 AM
davisflyer's Avatar
davisflyer
Cool! Which parts did you end up going with?
Old Mar 11, 2011 | 09:38 AM
redboy23's Avatar
redboy23
New Parts
gasket kit
timing sensor
idler pulley
arp studs
head bolts
timing chain
water pump
exspansion tank
fan belt
I might be forgetting some things.. my supercharger sounds a bit louder though. The previous owner had it rebuilt at 122,000mi. Should I worry about it? Car is way more responsive, and no CELS.
Old May 13, 2011 | 10:28 AM
goin440's Avatar
goin440
I have seen flow benches show JCW actually flows better than other aftermarket options. The aftermarket though can handle higher CFMs. The result changes the torque curve - why some people feel dead spots in their aftermarket upgrades (they loose all the low end torque). No one seems to understand that there is indeed a such thing as too much porting, especially when you don't match it to the right driving ~ like streeting a race cam - its useless.
BTW, anyone wanting Cooper NonS JCW?
See sig below for link to Market Place ---v
Last edited by goin440; May 26, 2011 at 07:07 AM. Reason: redirecting link to stay within NAM
Old May 26, 2011 | 05:49 AM
Professor's Avatar
Professor
Motoring Underground Parts Bin
I agree about the porting. Lots of people think bigger is better and more power, however most fail to consider their driving environment. Mike @ Thumper showed some images of a JCW head compared to stock. It appears they may be more work into the JCW head than most have thought.
Old May 28, 2011 | 07:15 PM
JumpingJackFlash
The only any quoted figure (in the NAM forums) I have ever seen is the JCW head has exhaust ports 4mm larger than stock, plus some mild porting.
Here's a couple of old threads with some info/pics:
- https://www.northamericanmotoring.co...close-ups.html
- https://www.northamericanmotoring.co...-jcw-head.html
My goal is to eventually get an upgraded head and cam, but not go crazy with it. Looking at somewhere around 250HP at the crank. Thumper's Stage 1 head/cam kit is a consideration (http://thumperheads.com/). You could always opt to get a stock S head and have it ported/polished yourself. Still thinking of doing that myself whenever I get around to this project.
Many want more, but I think that offers a good sweet spot for power and still have some daily driving capabilities. A 50 HP gain is alot when you consider MINIs weigh only 2680 lbs. empty.
Old May 29, 2011 | 06:43 AM
goin440's Avatar
goin440
I think going a mild cam on the stock head, doing intake/pulley and exhaust, and then an ecu tune would result in a very nice street friendly power curve.
I don't know what power that would get you to but the ecu tune alone would be very noticable.
Old May 29, 2011 | 07:27 AM
Mike@Tech Division's Avatar
Mike@Tech Division
This is a good option for the street. However new injectors and an I/C like the GP should be done too. The stock ones tend to tap out in the higher rpm range with pulley and cam combos.
phrza81
Oct 10, 2015 11:37 PM
caiken
Aug 27, 2015 06:55 AM
Aug 19, 2015 08:28 AM
MIminiclubman
Aug 5, 2015 09:14 PM
