JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW exhaust for 2010 MCS...
Old Mar 30, 2010 | 01:16 PM
///Mflossin's Avatar
///Mflossin
After a lot of "looking" around...I am thinking that the best exhuast system to use for my 2010 MCS is the JCW version. By this, I am talking about the center section that uses a single, long resonator to reduce drone found in the version with the catalyst. If I am correct in looking at realoem, I believe that all that I need for the conversion are the following:
P/N 18 30 7 587 361
P/N 18 30 7 587 363
The clamps, hangers etc appear to be totally interchangable. Can anybody who has done this confirm? Thanks!
Old Mar 30, 2010 | 03:54 PM
thevelourfog's Avatar
thevelourfog
I only installed the rear muffler, but kind of wish I did the front too. Drone isn't too bad, but it is louder than stock in the cabin at speed. Sounds a little wimpy, may need a downpipe too! Otherwise, yes, that's all you need. You need a clamp if you're not going somewhere to get it welded.
Old Mar 30, 2010 | 05:20 PM
kopov's Avatar
kopov
P/N 18 30 7 587 361
P/N 18 30 7 587 363
I have installed the JCW full exhaust. It is one long one piece, was taken off the JCW Mini. It fits my 2007 perfectly without any modifications or anything else. It is louder than stock and works well with the K&N intake and more aggressive ECU tune. It is a different car .
Old Mar 30, 2010 | 06:27 PM
thevelourfog
It's only one piece if it comes from the factory on a MINI, otherwise, have to order 2 pieces.
Old Mar 30, 2010 | 06:28 PM
///Mflossin
OK. I don't have the car yet so I can't see the exhaust. Does the clamp that you speak of currently reside on the MCS system or is this something that you refer to because I will need to source one separately? Thanks!
Old Mar 30, 2010 | 07:14 PM
thevelourfog
You need the clamp if you order it as 2 pieces, since it comes welded from the factory as 1 piece when it's on the car. If you take it to a muffler shop for install, you don't need it since they can weld it for ya.
Old Mar 30, 2010 | 07:17 PM
///Mflossin
Gotcha! I planned on doing this myself. Would anybody, including yourself, happen to know what the clamp p/n would be that I need?
Old Mar 30, 2010 | 07:28 PM
thevelourfog
http://www.realoem.com/bmw/showparts...=18&fg=20&hl=3
There's 2 p/n's with different prices, both should work. May want to ask Morristown MINI or whoever you buy from what the differences are; 18307525639 and 18307560778.
Old Mar 30, 2010 | 07:30 PM
thevelourfog
Also looks like you need a clamp for the front, dunno if you can reuse the stock one if applicable:
http://www.realoem.com/bmw/showparts...=18&fg=10&hl=3
p/n: 18302756352
Old Mar 30, 2010 | 07:33 PM
///Mflossin
hmmm...ok. I presumed that these clamps were already on the stock MCS exhaust system? My stock exhaust system must be welded on the MCS? That would explain my confusion. Same spec listed (55mm) so I wonder why the p/n's are different?
On a sort of separate note, is there a JCW catalog or something where one can see all of the JCW offerings? I assume a dealer is the place to get all JCW stuff?
Old Mar 30, 2010 | 08:16 PM
thevelourfog
Ya the stock system on your car will be welded, I'd assume the front clamp would be there though, but I don't know as I didn't change the front.
Old Mar 31, 2010 | 07:06 AM
///Mflossin
Agreed...the front clamp must be there judging by the configuration. Thanks for all your help and I'll post back once I am up and running.
Old Mar 31, 2010 | 09:37 AM
///Mflossin
FYI...my dealer stated that one clamp is needed. The clamp p/n is the one ending 778. The front clamp is the same between the two (off downpipe)
Old Apr 5, 2010 | 09:42 AM
///Mflossin
picked up the clamp and rear section of the exhaust today. The front half is on it's way from Germany. I am very impressed with the back half of this exhaust system...it looks and feels very nice in hand. The clamp is very nice as well. It appears that there will be zero cutting/trimming required on either piece from what I can tell. The clamp appears to have 50/50 engagement of the pipes. The camp is robust and has teeth/jaws to view full engagement. I will post once the front half is in and it's ready to go on. I assume, though, I might need to actually get the car first. Should be here in two weeks.
Old Apr 14, 2010 | 08:00 AM
Douglas H's Avatar
Douglas H
I was looking at the RealOEM.com website and wonder which of the two exhaust front section is the factory JCW version?
http://www.realoem.com/bmw/showparts...02&hg=18&fg=10
Second, the rear muffler appears to be the same picture for both the Cooper S and the JCW. What is the difference other than part number?
Old Apr 14, 2010 | 10:06 AM
thevelourfog
If you went through this thread, everything is already laid out. The front section is this:
Old Apr 15, 2010 | 05:21 PM
///Mflossin
I am waiting for my front section. It comes from Germany but that one piece is pacing all of the work that I have planned. I want to do all of it at once.
Old Apr 16, 2010 | 08:07 PM
juliansorl's Avatar
juliansorl
Very cool; Please post pictures of your project!!
Old Apr 22, 2010 | 09:19 AM
///Mflossin
Installed the full exhaust yesterday on my lift. Very straightforward and quite simply actually. I'd say it's a 2 star on a scale of 5. With 2 people/sets of hands...I'd say 1 star. I haven't really driven the car much but up the road and I can tell zero difference from the stock exhaust. It's very mild and quiet. I am assuming that the tone changes up around 4K RPM and higher. I am still in break-in mode though. The car only has 150 miles on it.
Pics and further review to come.
Old Apr 22, 2010 | 01:42 PM
thevelourfog
The exhaust will also get louder over the next week, mine took a couple weeks to get to it's max. loudness.
Old Jun 14, 2010 | 10:29 AM
quikjimmy's Avatar
quikjimmy
Factory JCW Exhaust?
I have been trolling through this thread and cant seem to find a reference to the part number on the JCW factory exhaust shown in the photo below.
I believe the part number is # 7585282, yet i cant find it on realoem or any other part sites.
Does anyone know if the factory exhaust has a special part number, and out of factory parts have different?
Old Jun 14, 2010 | 11:55 AM
jsargevt's Avatar
jsargevt
@qikjimmy - watching that JCW exhaust on ebay as well eh?
Old Jun 14, 2010 | 12:01 PM
quikjimmy's Avatar
quikjimmy
Yep,
Checking it out. I really want the entire one piece system though.
Old Jun 14, 2010 | 05:22 PM
jsargevt's Avatar
jsargevt
Same here....I think that it is the combo of the front and rear exhaust that is what we want.
I think that its auto setup to reject any "best offer" below the asking price....
Old Jun 14, 2010 | 09:00 PM
quikjimmy's Avatar
quikjimmy
If its the two piece system, then it must have been a retro fit. As im pretty sure that the factory JCW comes as a one piece.
Its not worth $250 thats for sure. You can get brand new ones for only $30 more shipped from the UK.
