JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
P2096.....What should I look for???
Old Mar 24, 2010 | 11:47 PM
davisflyer's Avatar
davisflyer
P2096.....What should I look for??? UPDATE
Last week I got a P2096 code and P2096 pending code while cruising on the interstate. I cleared it and it went away for about a week until I got back on the interstate at cruise, then came back. Both times were steady at 70 MPH.
Old Mar 25, 2010 | 06:23 AM
ron-s mini's Avatar
ron-s mini
I googled and found this:
http://www.myrotarycar.com/portal/fo...202000W03.html
This is generic code found on all cars (part of the emission standards so even though they are not specifically talking about a MINI the trouble shooting principles will be the same)
Leakage exhaust gas
• Rear HO2S malfunction
• IAT sensor malfunction
• ECT sensor malfunction
• AIR system malfunction
• Leakage intake-air
• Front HO2S malfunction
• MAF sensor malfunction
• Fuel line pressure malfunction
• Fuel pump unit malfunction
• Leakage fuel
• Ignition system malfunction
– High-tension lead malfunction
– Incorrect power supply to ignition coil
– Ignition coil malfunction
• Insufficient compression
Metering oil pump malfunction
– Engine oil condition malfunction
– Rised oil pressure
– Oil passage malfunction
– Engine malfunction
• Fuel injector malfunction
• PCM malfunction
Old Mar 25, 2010 | 06:58 AM
Helix13mini's Avatar
Helix13mini
You may have a shot cat.
Old Mar 25, 2010 | 02:54 PM
Some Guy's Avatar
Some Guy
Solution my dealer has applied to fix this problem. reset ecu, update ecu, replace bpv, replace intake tube, replace IC boots...
Old Mar 25, 2010 | 03:54 PM
davisflyer's Avatar
davisflyer
Great! Any of those work??
Old Mar 25, 2010 | 09:32 PM
yellowbritishrocket's Avatar
yellowbritishrocket
fuel filter...i think i had this code thrown at me while i was driving up mountains...check your filter if its dirty your car will lean out
Old Mar 26, 2010 | 07:41 AM
davisflyer's Avatar
davisflyer
How long do they usually last on these cars? Is it a DIY item, or take it to a shop kinda thing?
Old Apr 5, 2010 | 11:40 PM
davisflyer's Avatar
davisflyer
Going to the shop tomorrow. Will get the oil changed and front brake pads as well.
Will let you know the outcome of the code....
Old Jul 2, 2010 | 08:54 PM
davisflyer's Avatar
davisflyer
Ok, they found a intake leak in the BPV. New BPV on and code free for now. Fingers crossed
Old Jul 24, 2010 | 06:54 PM
davisflyer's Avatar
davisflyer
3 weeks and code free
Old Sep 16, 2010 | 03:14 PM
mr. jim's Avatar
mr. jim
How did they determine it was the bpv? I was on my way back from a trip to Ohio and on the last fuel stop the ses came on. When I got home I checked and found the P2096. I replaced exhuast gasket as it had a slight leak, cleared codes and refueled all ok. The next day ses came on again.
2006 S just turned 40,000 miles
