JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Went back to the DYNO today...
Old Dec 5, 2009 | 07:58 PM
scottab36's Avatar
scottab36
I took a trip back to the DYNO today after doing some MINI maintenance and the results were very suprising. Back in late March we did a DYNO day at Swift in Norwich, CT. This is the results on a 2007 JCW MCS. It did not print out the WHP which was 174WHP. Wheel TRQ was about 198ft lbs.
I was a bit disappointed with th results so I followed some advice and intuition and got much lighter wheels and a high flow air filter. The MINI had about 38,000 mile on it and I got the following results. 188.5WPH with 204ft lbs of TRQ. Not too shabby...
After much research and almost 45,000 miles on the MINI I decided to replace my fuel filter (another story all in its self) and I performed the Seafoam intake cleaning three times over two weekends. I took another trip back to the DYNO late this afternoon and got the following results. 199.4 WHP with 212ft lbs of TRQ.
I was not expecting that the new fuel filter and Seafoam intake cleanings would give me these results!
Could it have been that big of a problem?
Old Dec 5, 2009 | 11:08 PM
vjaramillo's Avatar
vjaramillo
I thought jcws put out 200 + stock.
Old Dec 6, 2009 | 03:45 AM
Julien321's Avatar
Julien321
JCW Stage 1 Tuning Kit is rated at 189HP (up from 172HP for standard S). The JCW's MINI has a (modified) different engine than the S. The JCW's is rated at 208HP. He has (or looks to have) a MCS w/JCW Stage 1 Kit and not a JCW.
Old Dec 6, 2009 | 05:11 AM
richardsperry's Avatar
richardsperry
Come on now, don't the MCS and the JCW have the same engine, but with different ancelleries and tuning?
Old Dec 6, 2009 | 05:21 AM
Gilboyto's Avatar
Gilboyto
Factory JCW has 10.1:1 compression while normal MCS has 10.5 (I believe). Also the factory JCW has a K03 housing turbo with larger internals (I think its from a K04) for increased airflow. Our cars generally run 10-13 psi stock, while the factory JCW generally hits 18-20psi.
Old Dec 6, 2009 | 05:54 AM
Julien321's Avatar
Julien321
I believe the JCW's has different piston heads than the S, in addition to what you posted.
EDIT: Just did a quick search and it does have different pistons. Here is a Motor Trend article.
Old Dec 6, 2009 | 05:56 AM
Gilboyto's Avatar
Gilboyto
Originally Posted by Julien321
I believe the JCW's also has different piston heads than the S.
Yep yep! Thats where the lower compression comes from
Old Dec 6, 2009 | 06:01 AM
Gilboyto's Avatar
Gilboyto
One thing Im curious about...since the factory JCW has a lower compression has anyone considered making a headspacer for the MCS to run the JCW turbo/specs?
The reason I ask is because it seems like it would easily be possible. On my 93 VW Corrado VR6 I ran a stainless headspacer on it to lower my compression by a full point to run the big turbo I had on it. Its basically just a piece of stainless cut into the same size/shapes as the block and head area so there is the oil and coolant cavities to pass thru it, and the piston holes as well.
Old Dec 6, 2009 | 10:37 AM
Robin Casady's Avatar
Robin Casady
The JCW pistons are designed to handle the higher boost. So, better to switch the pistons.
The JCW also has a more heavy-duty clutch and transmission.
Old Dec 6, 2009 | 03:01 PM
ThumperMCS's Avatar
ThumperMCS
I would just do it by switching the pistons. In addition to getting lower compression, you will also have much stronger pistons...so its like a two for one deal haha
Old Dec 7, 2009 | 02:53 AM
scottab36's Avatar
scottab36
You are correct but this is a 2007 JCW MCS with a few bolt ons. I am also using the 2009 JCW exhaust which has one less catalytic converter.
Old Dec 7, 2009 | 07:34 AM
Gilboyto's Avatar
Gilboyto
Just want to get clarifying information (sorry if it seems like Im hi-jacking). Why would you take the time to switch the pistons out, out of curiosity, rather than just get a headspacer to lower the compression? Getting a headspacer would be MUCH cheaper, and much easier to do IMO.
Besides, I mean the factory JCW has stronger pistons, but people on here with the R56 and GT28 with a higher airflow than our K03 have already proven that the pistons can seemingly take a pretty good beating without any detrimental effects, as well as the transmission.
Ive been trolling around but I havent seen any threads stating that too much boost has caused an engine to blow, or a transmission strip a gear from too much torque. I guess I just cant justify why you would go thru all the work of replacing the pistons rather than what is previously mentioned. I would expect to get better pistons if I planned on running 350hp, but Im never doing that again (let alone on a 1.6L) hahah.
Old Dec 7, 2009 | 11:41 PM
Sabes's Avatar
Sabes
You also have to remember we are talking about WHP here, not BHP... Jcw's put out 200+ bhp, but probably just under 200 WHP
Old Dec 9, 2009 | 05:38 AM
scottab36's Avatar
scottab36
Also this is a Stage 1 JCW kit with a lot of modifications, not a 2009 JCW. The Stage 1 JCW kit is rated at about 191 HP.
Old Dec 9, 2009 | 06:45 AM
lacning74's Avatar
lacning74
so the front pipe only has the resonator and no cat? would be fun to swap my MC front pipe for the JCW one. pipe sizes are off i know, but wonder if the length is pretty close.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
surfblue
Oct 24, 2018 01:20 AM
mct
Nov 29, 2015 04:51 PM
sungjk
Aug 5, 2015 08:23 PM
