adding JCW intake...
Thanks..that's kinda what I thought. Is the JCW intake plug and play then?
Many of us with the JCW intake (myself included) remove the flap and, therefore, the need for any wiring. Install is very straight forward this way.
Correct me if I'm wrong, but I believe Blimey chose to keep the flap operational because he has/had a very pronounced and annoying whistle from his throttle body or bypass valve at low rpms.
Yep - throttle whistle. Reason I bought the JCW intake - it's designed to reduce "undesirable" low RPM sounds while opening up at high RPMs to let the supercharger sing (and breathe).
While some do choose to go flap-less... the "standard" install really isn't that big a deal - took me 60-90 minutes, I'd guess.
That said, if you're gonna go flapless, I think you'd be better off with the Dinan intake... because that's basically what it is... a JCW intake with no mechanism. And cheaper.
bought 'em from sparkplugs.com
