JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW pulley remover?
Old Dec 24, 2007 | 05:05 PM
simplekid15's Avatar
simplekid15
JCW pulley remover?
Hello I was wondering is there a JCW pulley remover out there?
I can't seem to find one..
Old Dec 25, 2007 | 08:33 PM
simplekid15
anyone? bump.
Old Dec 26, 2007 | 01:07 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
I don't recall there being one.
Why are you looking for a JCW one?
Old Dec 26, 2007 | 02:27 PM
simplekid15
cuz I want to take the one off my GP and put a small one. :D
Old Dec 26, 2007 | 02:37 PM
glnr13's Avatar
glnr13
regular pulley removal tool, no JCW tool
rentable at your local auto parts store
Old Dec 26, 2007 | 08:15 PM
not-so-rednwhitecooper
When they put on JCW kits, they replace the entire supercharger, thus, no need for a factory tool!
Old Dec 27, 2007 | 01:15 AM
Luys's Avatar
Luys
I have talked to Mini-madness and they have Pulley remover but you have to buy from there the pulley. After using the pulley remover you have to send it back ot the company
Old Dec 27, 2007 | 05:02 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Yep - can be done with a plain-ole claw-type pulley remover. Most likely will destroy the pulley in the process.
Old Dec 27, 2007 | 05:36 AM
pmello's Avatar
pmello
You can cut down one of the cheap aluminum mini puller types to close up the gap. Some pulleys are really on tight, yet others require very little force. I was able to remove a JCW with the cut down trick! The puller should still work with some longer bolts for the stock size. Just be careful that all force is applied between the front end of the shaft and the pulley itself. At no time should any force be applied between the pulley and the supercharger aluminum body or any side to side pressure anywhere!! It has to come straight off from the pressure to the tip of the shaft by the center screw of the puller. If you muck it up with a 3 jaw pulley puller you can drill and tap the pulley for some some 5/16 bolts and a suiteable puller.
bobbiemartin
Jan 20, 2016 05:28 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
