JCW Suspension: Value and Lowering
I was under the wrong impression that when I bought my factory installed JCW, it came with the JCW suspension. So, I'm wondering now who has upgraded from MCS Sports Suspension to the JCW suspension and if they thought the difference was noticeable and worth the money.
Also, was wondering if anybody knew exactly how much the JCW suspension lowers the car if at all.
THanks.
THanks.
I think it's a fantastic "street" suspension setup. The only addition that might be worth considering is a stiffer rear sway bar. I haven't added one yet but I do plan to.
If you want to go with track-focused stuff, you'd be better spending your money elsewhere though. While it will indeed be an improvement on the track over stock, that is not its intent.
If you decide to get it, be aware that there are four different spring rates available - designed to be tuned to the options you have on your car. You should buy from a source that takes that into account, and gives you the appropriate part number (they should be able to glean it from your VIN).
For a dual purpose (street & track) car, the JCW suspension works great. Yes, there may be better solutions for a track only car. But, most of those won't be very comfortable on the street.
The JCW suspension lowers the car approximately 10MM (.3937) from the stock suspension. I have found that it is a very good compromise for a street aggressive driver. It will make your MINI stay fairly flat in aggressive cornering, ride quality is pretty good, will not overly drop ride height to prevent from wearing other suspension components, and as others have said the spring rates are designed for the weight of your car. IMHO I think it is a good buy for the $$$.
Steve
Steve
Aug 19, 2015 12:51 PM
Minibeagle
Aug 13, 2015 10:00 AM
