Interior/Exterior Speedo removal - help
Old Mar 31, 2007 | 11:36 AM
RichardF's Avatar
RichardF
I have a 2003 MCS. I am trying to hook up a wire for the OBC and am stuck at the speedo trim removal. I have the three torx's removed and the panel won't come off. Do I have to remove the top dash panel to get the speedo piece out? In posts about changing the gauge faces people make comments about unplugging the speedo can cause problems. Has anyone had an issue after adding the OBC?
Second question is for the power tap which wire on the bottom of the lighter is the power? I really need to get a shop manual but have only had the car 6 weeks. I might have a line on a power tap but was wondering about taping in to the bottom of the lighter.
I have searched and the "onboard_computer.pdf" instructions just say pull the panel off.
Old Mar 31, 2007 | 02:01 PM
rkw's Avatar
rkw
These have descriptions of speedo removal:
https://www.northamericanmotoring.co...ad.php?t=91311
http://www.cockpitspecialties.com/instructions.pdf
For the lighter, + is red/black/yellow wire, - is brown wire.
Old Mar 31, 2007 | 06:26 PM
Wake|MCS's Avatar
Wake|MCS
For the speedo removal, grab the bottom right of the panel and pull hard, it'll come off. From there do the same on the bottom left. Then just give it a tug on the top and its off. Use discretion but at first it'll feel like your pulling way to hard. Can't help you on the rest though.
Old Apr 1, 2007 | 07:41 AM
RichardF's Avatar
RichardF
I just undid the passenger side of the dash and that gave me enough room to pull the speedo cover. Dang the dash is hard to put back on afterwards.
On the power side I managed to find a proper add-a-circuit so I won't have to tap into other wires.
Crimguy
Sep 10, 2015 01:07 PM
ltjpunk7
Sep 6, 2015 07:32 AM
jesterofatlas
Aug 31, 2015 07:58 AM
greekzilla
Aug 23, 2015 03:44 PM
Herleman
Aug 16, 2015 06:41 PM
