Interior/Exterior Light Bars: Palo or Alta??
Old Dec 5, 2006 | 08:41 PM
MCSMiami's Avatar
MCSMiami
I'm considering purchasing a light bar...which do you guys recommend? Comments/Suggestions appreciated, thanks.
Old Dec 5, 2006 | 09:29 PM
nypepper's Avatar
nypepper
you should buy my alta so i can buy the palo uber
Old Dec 6, 2006 | 01:03 AM
Uncl3's Avatar
Uncl3
If you want now, I would suggest Alta. If you can wait til January, I've heard that a reputable NAM sponsor/vendor is going to put one out that suppose to be better than both of these. This is why I'm holding off until then.
Old Dec 6, 2006 | 02:44 AM
rivet's Avatar
rivet
Tease! Any more info than that?
Old Dec 7, 2006 | 01:21 AM
Uncl3's Avatar
Uncl3
I actually don't have any info to release and it's not really my place to do so. When I placed an order for an AGS system, I asked about the bar because I heard from word of mouth about it. I wanted clarification that they were going to produce it and when so that I could hold off on buying the light bar and compare to the other two. Sorry to tease you but I thought I'd let you know before you bougth one.
Old Dec 8, 2006 | 05:15 PM
MCSMiami's Avatar
MCSMiami
How much?
Old Dec 8, 2006 | 06:17 PM
Grassroots Garage's Avatar
Grassroots Garage
The Rangeline mounts are very sturdy and eay to install, they work with any light kit. They are $160/pair
Old Dec 8, 2006 | 06:20 PM
Morris9982's Avatar
Morris9982
I like the look of the lights mounted on the bumper. Can any be mounted without having to cut something? In other words, can you take them back off with out being able to tell they were ever there?
Old Dec 8, 2006 | 09:57 PM
nypepper's Avatar
nypepper
Originally Posted by MCSMiami
How much?
$275 with the 4 white lights and a custom switch
the ipf switches suck mine broke after 2 weeks of use
Old Dec 9, 2006 | 01:17 PM
Grassroots Garage
With the rangeline brackets, you need to cut 2 small sections (4 if you have 2 pair installed) out of the lower grill, If you were to remove them, the grill could be replaced cheaply while the bumper cover is off. I like to use the PIAA 540 which I retail for $249. The brackets are $160 for the pair, and I charge $275 for installation.
--Dan
melscoop
Mar 30, 2016 06:56 PM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
jrezzo
Aug 9, 2015 10:32 PM
