Interior/Exterior Door edge covers???
Old Apr 6, 2003 | 11:58 AM
MJC1880's Avatar
MJC1880
Anyone know where i can get chrome door edge covers to protect from walls and other cars hitting mine. I have tryed to find something but have had no luck.
Old Apr 6, 2003 | 02:07 PM
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
Or, alternatively, I would like to find strips of 3M Stonegard (or similar) to do the same type of thing, just more invisible. Is this sold in custom sizes?
Old Apr 7, 2003 | 04:07 PM
Davbret's Avatar
Davbret
MINI-Madness sells a package of door cup and door edge guard in the Stoneguard material. $65.
R
Old Apr 7, 2003 | 04:24 PM
Verruckt's Avatar
Verruckt
Yup. The door cup guards are a littlte difficult to install if you've never done it before, primarily becasue the instructions are really bad (for someone who has never done it before). I lost the first one I tried, so I now only have it on the driver's side. The door edging is simple as dirt to install, though, and is invisible to anyone short of the guy you shelled out $100 to for detailing.
Old Apr 9, 2003 | 09:41 PM
sirron's Avatar
sirron
Pep Boys...less than $15.
Old Apr 10, 2003 | 06:08 PM
115hp's Avatar
115hp
My local Wal-Mart has them in both chrome and black.
Old Apr 11, 2003 | 07:51 PM
ScooterMan's Avatar
ScooterMan
On the door handle cups (chrome ones)....If you get them, check them for fit BEFORE you try to install them. They can go in two ways, but only one is right. I prefit BOTH sides and labled them Driver and Passenger with each also having an arrow pointing up so that when I finally put them in I'd know which is up and which side goes to which door. I also cleaned the door with denatured alchohol, filed the nubs off the back and removed the cheap double-sided tape that came with them then used dollups of an auto silicone type glue (Goop) and let them dry overnight. Seems to be working fine.
Did the same thing with the chrome vent covers.
_________________
Fix it 'til it breaks
Old Apr 13, 2003 | 10:44 AM
pinz1974's Avatar
pinz1974
Go the Clear-Bra material route. I got the cheap black plastic Pep-Boys models. They were a little thick and shifted a little over time (outward toward the door jamb) so that they started to rub just slightly every time I closed the door. I pulled them off and noticed that they had done a serious number on the clearcoat on the edge of the door from the small amount of dust/dirt under the edge of the guard acting like sandpaper every time the door closed. It took me about four hours of rubbing with a mild polishing compound to get the mark off (or at least nearly). :???:
woodstudio
Mar 15, 2020 08:28 AM
xpunisherx
Sep 1, 2015 11:47 AM
davavd
Aug 25, 2015 10:08 AM
wabiker3576
R55 :: Clubman Talk (2008+)
Aug 18, 2015 08:48 PM
ludedude
Aug 10, 2015 07:16 PM
