Interior/Exterior painting brake calipers.
Old Aug 21, 2006 | 07:58 AM
minimusprime's Avatar
minimusprime
So my dad is helping me do some work on my car this weekend as a sort of bonding thing i guess .
Any way he wants to paint my stock brake calipers. I found this kit online.
http://www.tirerack.com/brakes/g2/caliper_paint.jsp
Any one have any idea if this kit works well at all? I am really kinda worried about ending up with a crappy honda civic looking job on my calipers and im hoping that the finish of this wont look that way. I plan on changing to stoptech calipers and new rotors in the future (maybe a year or two) so i guess it doesn't matter.
I guess I'm asking is this worth it and will it look decent in any way.
Old Aug 21, 2006 | 08:02 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I used the G2 kit on my calipers. It works pretty good...
mdsbrain's Avatar
mdsbrain
Its just like the kit from Duplicolor which you can pick up @ most local auto parts stores. Usually the paint lasts 6 months or so before needing a repaint.
Old Aug 21, 2006 | 08:16 AM
Partsman's Avatar
Partsman
Legion_of_Doom
I've had mine on for more than 6 months, I drive it everyday and they still look good. They could use a cleaning.
Old Aug 21, 2006 | 09:25 AM
mini-rolls's Avatar
mini-rolls
I have had mine on for two years and it still looks good. Just clean them when you clean the wheels.
Old Aug 21, 2006 | 09:48 AM
minimusprime
Originally Posted by mini-rolls
I have had minie on for two years and it still looks good. Just clean them when you clean the wheels.
did you use the kit i posted a link to or some other one?
Old Aug 21, 2006 | 11:56 AM
One-D's Avatar
One-D
Just a suggestion for others (for future brake work)--- remove the retaining spring that holds the carrier to the caliper when you paint it as well as making sure the 2-part paint does not clog the holes for the retaining spring.
Old Aug 21, 2006 | 12:04 PM
polizei's Avatar
polizei
http://www.g2usa.com
I've heard good things about them, and PARTSMAN used this kit, however I've not personally used it.
Moss MINI sells the kits: http://www.mossmini.com/Shop/ViewPro...eIndexID=36138
-Cody
Old Aug 21, 2006 | 12:32 PM
cooper99's Avatar
cooper99
I went to Advanced Auto and picked up their Dupli-color brake caliper paint kit for about $18. It includes aerosol caliper cleaner, a can of red paint (good for painting about 100+ brake calipers), and a paintbrush. The paint claimes to withstand temperatures up to 500 degrees. If you ever track your car, your brakes will probably get much hotter than that, but for 95% of daily driving its just fine. I have had mine painted for a week so far and they are still shiny red.
If you still have stock brake pads with lots of dust, I would recommend you to get some EBC Greenstuff pads or Hawk HPS pads with about 10x lower brake dust and your calipers and wheels will stay cleaner and look better a lot longer.
Old Aug 21, 2006 | 01:18 PM
mini-rolls's Avatar
mini-rolls
I used the G2 kit.
Old Aug 21, 2006 | 01:45 PM
neilgj's Avatar
neilgj
I used the G2 kit on mine. It works well but you ought to get yourself another can or two of brake cleaner (the kit comes with one can), particularly if you have an older car. The paint will stick to the dirt and not the caliper, so you want to make sure those babies are nice and clean (or as close to nice and clean as you can get).
Also, you can get the kit a little cheaper on eBay.
Old Aug 21, 2006 | 06:21 PM
MINI Monkey's Avatar
MINI Monkey
I used the G2 kit as well. They still look great a year later.
Old Aug 23, 2006 | 07:11 AM
Pir8 97's Avatar
Pir8 97
I used the G2, but I got it from Out Motoring
Old Aug 23, 2006 | 12:13 PM
ylwjkt's Avatar
ylwjkt
I used the Folia Tec, which is the same as the G2. The "Speed Yellow"
is a true yellow that matched the LY better than the Duplicolor, and
they also offer some other interesting colors. Folia Tec is a German
Company that claims to have colors that match the paint on European
cars more closely than other brands. When you want to paint the calipers
on your Elise a stunning Krypton Green, this is the brand for you.
Old Aug 23, 2006 | 12:32 PM
pinkmini's Avatar
pinkmini
What about custom colors? I want to paint my calipers pink, and I am getting white rims. So can I use any dupicolor paint or only the paint in the kits?
Old Aug 23, 2006 | 12:44 PM
ylwjkt's Avatar
ylwjkt
The only pink paint I know about is engine paint. It is VHT
brand made by Speco. I don't know if this would work on calipers
or not - maybe some tech-savvy gurus can advise?
http://www.speco.com.au/vht_engine.html
Old Aug 27, 2006 | 02:21 AM
OctaneGuy's Avatar
OctaneGuy
I just painted my calipers using VHT. I bought Red and Yellow cans, and sprayed them into a jar to mix. Then used a disposable brush to apply to calipers. I wanted Orange and got it!
Each coat dries in 20 minutes or less. I found that the first coat looks thin, but takes only minutes to dry enough so that you can begin adding new coats.
The paint is rated up to 900 degrees and is called brake caliper paint.
Old Aug 27, 2006 | 03:02 PM
IrishCooper's Avatar
IrishCooper
Anyone have the link for Folia Tec or VHT
Old Aug 27, 2006 | 04:20 PM
OctaneGuy's Avatar
OctaneGuy
VHT Brake Caliper, Drum, & Rotor
900degF
SP-371 Racing Red
MFD for PJH Brands, Scottsdale, AZ 85258 USA
Aww my store didn't have Orange, and so I bought Red and Yellow paints to mix. Seems Orange does exist.
http://www.cacustomcoatings.com/orange-paint.html
I couldn't find a single mfg website for VHT, so just google
VHT Caliper Paint PJH
Did this last night.
BEFORE
AFTER
Old Aug 27, 2006 | 04:28 PM
OctaneGuy's Avatar
OctaneGuy
Before removing the wheels, this is what it looked like!
Masked and painted. I just painted what was visible. I haven't done the rears yet, not sure if I will yet.
Masked and painted from 3/4 front view.
Masked and painted.
Small jar for mixing paints and storing excess.
VHT Caliper paints--good to 900deg!
Brake cleaner!
Disposable paint brushes!
Disposable rubber gloves are essential!
After painting and cleaning up, I reinstalled the wheels to let the paint dry over night--well it was 3:30AM already, so over night wasn't very long!
Ok, so it's not the hot orange I was hoping, but it looks hot regardless!
Close up of painted calipers. I tried to go for an Orange look, but kinda ended up muddy red.
The next day
a quickr pickr post
Old Aug 27, 2006 | 05:39 PM
moreorless's Avatar
moreorless
I used the Duplicolor caliper paint kit from Wally World. Painted them twice in one session. You know, start on the right front and work your way around the car. By the time you get back to the right front everything is dry and you do it again. There's enough paint in that can to paint your calipers once a year for 3 or 4 years.
1 year and 20k miles later they still looked swell but I cleaned them real good and slapped on another coat.
Can't beat the price!
....Les
Old Aug 28, 2006 | 02:39 PM
jst4fun's Avatar
jst4fun
Coordinator :: Alabama Motoring Society
Did not listen to Thread and got burned.
Here is Dupli-color yellow.
Took me 5 coats and still have bloches.
My advice is don't get this product.
Old Aug 28, 2006 | 04:10 PM
minimusprime
I painted mine this last weekend. I used the kit that i purchased from tire rack and they turned out great. I went with red as my car is red and im going for a cr/bl theme.
I did two coats on mine and they seemed thick enough even though i had a bit of extra paint left. Ill post pix later but the thing is they dont really shine through my s-lites, not to worry though those will go soon.
thanks for the suggestions guys.
Old Aug 28, 2006 | 04:22 PM
MLPearson79's Avatar
MLPearson79
Hmmm....would calipers look stupid painted PW?
I can handle not being able to do the headlights...but this looks too fun (and a lot easier!).
Old Aug 28, 2006 | 04:31 PM
minimusprime
I think they would look great although hard as heck to clean. Worth a shot and I haven't seen it yet so you would at least have something different looking.
