Interior/Exterior Viewing Tach
Old Jul 29, 2006 | 04:03 PM
royal4mac's Avatar
royal4mac
Viewing Tach
OK, I looked for this subject, maybe I missed it, or maybe there is no easy cure.
I am around 6' and the top of the wheel cuts off the upper 50% view of the tach. I drive by listening to the engine, but being new to the Mini, I look at the tach probably more than I will after driving it for a few more months..
But, is there some way to offset the tach to the side, or raise it? Raising it is probably not a good idea, but I figure most folks must have this same problem.
Old Jul 29, 2006 | 05:22 PM
kapps's Avatar
kapps
There's no real way to move the tach but... Make sure your seat is in the lowest position (with the rachet on the left). Also, the wheel can be raised (unlock mechanism under the wheel). If you like your current position, your probably out of luck.
Old Jul 29, 2006 | 05:54 PM
Partsman's Avatar
Partsman
Legion_of_Doom
As long as there is enough slack in the harness, it wouldn't be that hard to raise it.
Old Jul 29, 2006 | 07:17 PM
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
I am 6'3" and I have NO problem seeing the tach. Perhaps you just need to play with the seat adjustment.
Old Jul 29, 2006 | 08:08 PM
skitelluride531's Avatar
skitelluride531
There isn't...atleast not in mine. I have had the tach off several times, and there hardly is enough slack to disconnect the harness from the unit.
I'm 5'11, and have the steering wheel in the lowest position, same as the seat, and the steering wheel cuts of the speedometer from about 60MPH to the 120 MPH range...luckily, if I am ever driving in the lower part of that range, it is with cruise control on so it isn't much of a bother for me.
PsychoRallye
21
Feb 17, 2019 06:08 AM
EVMini
Sep 28, 2015 10:20 AM
Sep 25, 2015 12:32 PM
bobbi.steines
Sep 10, 2015 11:31 AM
caiken
Sep 7, 2015 09:10 PM
