Interior/Exterior how to remove the antenna on the roof?
Old Jun 23, 2006 | 11:10 AM
hppsco's Avatar
hppsco
Hey guys!
I need to know the thread on how to remove the antenna on the roof so I can apply Mike's checkerboard vinyl.
Please let me know how!
thanks,
Stacy
Old Jun 23, 2006 | 01:11 PM
Snappychip's Avatar
Snappychip
What year do you have and are you sure you need to remove it to install the checkered board? I know with my factory checkered board I didn't have to remove the base because there was no square there. I think to remove the base of the antenna you have to go from the inside above the headliner.
Old Jun 23, 2006 | 01:35 PM
hppsco's Avatar
hppsco
i have an '05, and the vinyl came from Asthetic Creations, not from MINI. I'll look to see if there is a hole, but somehow I doubt it.
Old Jun 23, 2006 | 03:56 PM
Kentiki's Avatar
Kentiki
i have an 05 also. You need to pull down the rear of the headliner, and up in there is a hole with a nut you can unscrew to remove the antenna base. a bit of a pain, but it's not too bad.
Ken
Old Jun 23, 2006 | 04:15 PM
hppsco's Avatar
hppsco
Hi Ken,
the headliner is easy to pull down without making it dirty?
where do I grab to get underneath it?
or do I somehow pull out the rubber gasket around the rear hatch and go in from there, any tips on how you went about it?
Stacy
Old Jun 23, 2006 | 05:48 PM
Partsman's Avatar
Partsman
Legion_of_Doom
On my black '03, I just unscrewed the antenna and wiggled the little black base a little and it popped right off. Then you can checker the spot and put the base right back on, nice clean look.
Old Jun 23, 2006 | 06:05 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
There are some notes on my web:
http://gandini.unm.edu/PGpages/Interests/XMantenna.htm
These may help you. There are also other posts if you search for XM antenna base.
good luck,
Old Jun 23, 2006 | 08:45 PM
Kentiki's Avatar
Kentiki
The headliner didnt get dirty, but did wrinkle. The wrinkles smoothed out in a day or so. You do need to pull the black rubber weatherstrip off a bit, and the vertical gray posts on either side (between the hatch and rear windows). When you pull off the weatherstrip, you'll almost be able to see where the antenna nut is up in the roof.
Good luck and -- don't be afraid to pull!
Old Jun 24, 2006 | 04:33 AM
hppsco's Avatar
hppsco
is there an information page somewhere?
yikes!
now I dont know which is correct.
The antenna is not an xm, i know this. It is just a regular small oval, with the thinnest small spiral stick attached to it.
I was thinking maybe a heat gun, like when I used it on the cooper letters on the boot, but I am not sure whether or not it is just stuck or screwed. For some reason, Ithink it may be screwed. It wiggles but doesnt come off, that would indicate to me another form of attachment.
Is there a thread that shows all the different kinds of antennas and their methods of attachment?
thanks,
Stacy
bugeye1031
Aug 15, 2015 08:14 AM
Aug 12, 2015 01:24 PM
Dashdog
Aug 10, 2015 06:17 AM
