Interior/Exterior Shift knob idea
Old Mar 9, 2003 | 09:27 PM
Azwed's Avatar
Azwed
I am trying to make my MINI as close to dual-tone as possible. I am getting Chili Red w/ black roof, mirrors and wheels. I want the car to be as close to just black and red as possible so I was thinking it would be cool to put a number 3 billards ball as the shift ****. Most of the number 3 ***** are almost the same as red as the Chili red.
At the same time I would like the heavy feeling that many of the aftermarket ***** give. Do you think it would be possible to modify the billard ball in someway to mimic that feel? I mean could you cut one in half and fill it with lead or something?
Just thinking out loud right now.
Old Mar 9, 2003 | 09:35 PM
SCCA's Avatar
SCCA
I dont think you could cut one in half and make it right again but i see no probs with boring one out and adding the correct insert to make it work. I think the billard ball will have about the right weight to it as is and I've done this sorta thing before...although not with a billard ball but I like your idea!
Old Mar 9, 2003 | 09:45 PM
Azwed's Avatar
Azwed
Yeah i didn't really think you could cut one in half and get them back together intact.
I had been thinking that you could drill a hole through the bottom then fill in part of the gap with lead.
How much do those short shift ***** weigh anyway?
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
I have a feeling that 8ball might be able to give you some good advice about this!
Old Mar 9, 2003 | 09:46 PM
Azwed's Avatar
Azwed
I would probably get a 3 ball and an 8 ball just to see which one would look better.
Not sure how the one spot of red will look in an all black interior.
Old Mar 9, 2003 | 09:50 PM
SCCA's Avatar
SCCA
Yes...bore it out oversized and I suppose lead would be strong enough to hold insert or fill maybe just the majority with lead and install the insert with something a little tougher like JB Weld for example...that should work
Mini2Go's Avatar
Mini2Go
You might want to send him a PM to ask him. Like I said though, my mind might just be playing tricks on me.... Either way, 8ball is cool, I'm sure he won't mind a PM!
Old Mar 9, 2003 | 09:54 PM
Mini2Go's Avatar
Mini2Go
>>Not sure how the one spot of red will look in an all black interior.<<
BTW, I'm not sure either, but it does have potential to look pretty cool, IMO.
_________________
Old Mar 9, 2003 | 10:10 PM
8ball's Avatar
8ball
I was searching around a little bit and found a couple of good '8-ball' ***** but then stumbled onto the Whelan solid polished stainless steel ...
... the best 'real' billiard-type was from http://www.flameball.com - I did get one but it had threads for my Classic; They were talked about in a few other old threads so maybe they've got a good clip-on one now instead of just screw-on. They also had a RED 8-BALL (picture on their site)! Searching other shift **** or billard ball suppliers didn't get me anywhere so I was so glad when I found the steel one ... you might want to look into that if you are after weight - then take it to your local custom painter and apply the billard theme ...
Old Mar 9, 2003 | 10:15 PM
Azwed's Avatar
Azwed
Cool thanks for the link. Another reason I would like the billard ball was because I thought it would not feel nearly as cold/hot as the metal ball.
Old Mar 9, 2003 | 10:22 PM
8ball's Avatar
8ball
... the ball I got from Flameball feels great ... I was to follow through and get him dimensions for the MINI shift lever but got the steel before that ... He seemed like a very accomodating guy who would probably work with you to get the hole size right ..
Old Mar 9, 2003 | 10:27 PM
Azwed's Avatar
Azwed
Cool I will have to contact him once I get my MINI.
patsum
26
May 29, 2021 06:29 PM
donniedarko
Oct 21, 2015 01:15 PM
eliseo1981
Sep 30, 2015 01:53 PM
OdzBodkinz
Sep 11, 2015 07:20 PM
SneedSpeed
Sep 2, 2015 05:34 AM
