Interior/Exterior Clear protective light shield installation tips.
Old Mar 24, 2006 | 02:37 PM
daemon2's Avatar
daemon2
I will be installing these light shields over the weekend, has anyone used these from MossMini? Any tips on installation?
I see a few warnings in the instructions about fingerprints and fog under the shield after install. Any tips would be great.
Thanks!
Old Mar 24, 2006 | 03:03 PM
Crashton's Avatar
Crashton
I have a set of those too. Mine are on the garage shelf waiting for a warm day to get them on. Looking forward to any tips.
Old Mar 24, 2006 | 03:28 PM
francisk's Avatar
francisk
You need hair dryer... just heat it up, then the shield will become soft. And you can contour it to the headlight.
Old Mar 24, 2006 | 03:30 PM
daemon2's Avatar
daemon2
It says something about extra material building up on the edges, do they stretch when warm?
Old Mar 24, 2006 | 03:42 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Make sure your hands stay wet with the water/alcohol solution when handling the shields. Be patient, the shield WILL conform to the headlight. Squeegee the hell out of it. The haze between the shield and the headlight WILL go away, just don't hold your breath though.
Old Mar 24, 2006 | 03:44 PM
daemon2's Avatar
daemon2
What do you mean, just don't "hold your breath"? BTW, where did you get your DINAN airbox?
Thanks for the feedback everyone.
Old Mar 24, 2006 | 03:58 PM
Partsman's Avatar
Partsman
Legion_of_Doom
The haze will take a long time to go away, anywhere from a few weeks to a month or more, if it's warm where you are it might not take as long.
The MINI dealer that I used to go to is obviously also BMW, and they do Dinan there as well.
I still get parts from there, but the tech that works on my car is at a different dealer now.
Old Mar 24, 2006 | 06:21 PM
thulchatt's Avatar
thulchatt
Also use a lot of the wetting solution to keep from getting finger prints and take your time.
When I did mine I thought I would never get them streched out. I just kept using my hands to smooth out the plastic. It took about 30 mins to get them completely flat on the lights.
Also, as said above, don't worry about the hase when you first install, it will go away.
Old Mar 24, 2006 | 06:28 PM
daemon2's Avatar
daemon2
Thank you. I will get this done over the weekend.
Old Mar 24, 2006 | 06:49 PM
hong's Avatar
hong
You can find some detailed information here http://www.autopaintguard.com/installation.html, that where I bought mine from, the kit came with an instruction video disc, that guy makes it look so easy.
I did the hood piece myself, it's a hell of work requiring a lot of patience. Although I have done it once on my another car with ease long time ago, I'm not too happy with the Mini job due to the much rounded hood. Headlight installation should be straightforward I hope.
Old Mar 24, 2006 | 10:47 PM
kenchan's Avatar
kenchan
i used a heatlamp to warm it up before applying it over the lamp. otherwise, the cover will not contour very well to the curvature of the lens.
Old Mar 25, 2006 | 06:51 AM
francisk's Avatar
francisk
They won't stretch alot when warm, so don't worried about out of shape.
When there is bulge show up on the shield.. just heat it up spray the solution and push it down.
Also don't worried about the haze, they will gone eventually.
Old Mar 25, 2006 | 02:00 PM
Crashton's Avatar
Crashton
Thanks for all the great tips given here. Especially the one about the haze taking time to go away. I know that would've made me go crazy.
Old Mar 25, 2006 | 02:48 PM
mini-rolls's Avatar
mini-rolls
It is like installing window, the biggest trick is to use lots of solution, it will allow for positioning and keep the finger prints out. Ensure the lens is really clean also. Use a heat gun after positioning and a small plastic squeege with a soft microfiber cloth wrapped around to get the water and air bubbles out. I did both my MINI's never had air bubbles or any issues. Take your time and do not get them to hot.
Old Mar 25, 2006 | 08:06 PM
daemon2's Avatar
daemon2
Done. These went on like butter. Thanks for all the tips guys. Now I can take her for a spin in the morning and not worry about catching a rock on the lights.
Sexual Chocolate
Mar 31, 2019 08:02 PM
Dec 23, 2015 10:36 AM
squawSkiBum
Oct 2, 2015 09:21 AM
bctf1
Aug 6, 2015 12:55 PM
