Interior/Exterior "Official" MINI exhaust tips ?
Old Mar 16, 2006 | 04:33 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Hi motorers
My minds may be playing tricks on me, but I think I saw here a "new" part from MINI a little while ago...
I was new exhaust tips that changes the small stock ones...
Anyone has a part number for those, if they exist?
Any help would be greatly appreciated!
Old Mar 16, 2006 | 04:34 PM
chows4us's Avatar
chows4us
http://www.realoem.com/bmw/showparts...49&hg=18&fg=95
Old Mar 16, 2006 | 04:39 PM
Motor On's Avatar
Motor On
there is already a thread with photos, $99 from the dealer, look pretty good on the PW/B MINI, I'll see if I can find a link.
Old Mar 16, 2006 | 04:41 PM
DarkMiniCooperS
Thanks for the help!
I found them on Lauderdale's website
http://www.parts.com/partlocator/ind...catalogid=3751
Old Mar 16, 2006 | 04:45 PM
DarkMiniCooperS
If you can find the link, I'd really appreciate !!
Old Mar 16, 2006 | 04:56 PM
Trip024's Avatar
Trip024
pics?
Does anyone have this installed on their MINI? Pics would be awesome
Old Mar 16, 2006 | 05:01 PM
Motor On's Avatar
Motor On
https://www.northamericanmotoring.co...t=exhaust+tips
Pics included esp. pg 2
Old Mar 16, 2006 | 05:16 PM
DarkMiniCooperS
Thanks a lot Motor On!
I just bid on those on eBay. A set from Morristown MINI.
Old Jun 14, 2006 | 04:38 PM
RHM's Avatar
RHM
Exhaust Tips
I just purchased and installed the official replacement exhaust tips on my MCS. The stock exhaust tips are each attached with a hex set screw. Loosen the screw, slip off the stock tip, slip on the replacement tip, and tighten its set-screw. A five minute job that my dealer wanted $22 for (plus $99 for the exhaust tips). As the stock tips mount identically to the replacement tips, why doesn't MINI offer the replacement tips as an option when ordering, especially as so many other things are so customizable on the car. (But then they probably couldn't charge as much).
Old Jun 14, 2006 | 04:43 PM
AndyRew009's Avatar
AndyRew009
here is a picture. if you get them i suggest that you drill holes in your pipes so they dont fall off.
please dont ask me how i know that.
Old Jun 15, 2006 | 06:46 AM
omascow's Avatar
omascow
Here is a picture of mine, however I painted the inside with high temp black paint.
Old Jun 15, 2006 | 07:13 AM
DesignIt's Avatar
DesignIt
Hmmm, this looks a lot like the Cooper tips I put on my MCS a couple of years ago.
https://www.northamericanmotoring.co...00&ppuser=9851
<edit> I should tack on a disclaimer about using the optional Cooper tips. When I did this, there was not a part for the MCS, so I had to weld up a couple of adapters to fit the Cooper diameter tip to the MCS diameter exhausts. On the first try, I used steel tubing to make the adapters, but that lead to a continual rust problem. I finally found stainless steel parts online at Burns Stainless. The bottom line is, the new tips that fit the MCS are worth the price compaired to what I went through.
Old Aug 12, 2006 | 01:29 PM
qweewq12's Avatar
qweewq12
here are mine... I like them..much better than the beer cans... they should come on all MCS...
Old Aug 12, 2006 | 05:03 PM
Passat774's Avatar
Passat774
Great job with the painting them black... they look much better that way!!
Old Aug 13, 2006 | 08:59 AM
DDodge's Avatar
DDodge
I got them from OutMotoring:
http://tinyurl.com/juyxh
I painted the insides as well. The light color they come with discolors badly from the water in the exhaust. Pic is pre-painting. I just used flat black model paint - it's still on there.
Old Aug 13, 2006 | 11:19 AM
DarkMiniCooperS
No need to paint the inside black... It will get black in no time lol
Mine are now black and there's not a single silver spot anymore
Old Aug 13, 2006 | 11:46 AM
irieman's Avatar
irieman
Chrome Exhaust Tip Cooper S (Set of 2)
Item #82 12 0 410 150 ($99 dealer price)
I did order these with my MCS, but ended up installing them myself for the sake of time... (painting them black? = so stolen! )
Attached Thumbnails &quot;Official&quot; MINI exhaust tips ?-tips01.jpg   &quot;Official&quot; MINI exhaust tips ?-tips02.jpg   &quot;Official&quot; MINI exhaust tips ?-tips03.jpg
Old Sep 24, 2006 | 09:50 PM
Tea Rex's Avatar
Tea Rex
Re:exhaust tips. Two questions. Did they change the sound? Was the install (and removing the old ones) easy with just an allen wrench?
Old Sep 24, 2006 | 10:00 PM
irieman's Avatar
irieman
sound: i'm pretty sure there is no change, but i can't really tell, since i'd only had the car for a couple days before putting the tips on... (warrants a side-by-side w/ a stock MCS i suppose)
install: 1 allen wrench, five minutes, and a mirror (i was lazy so i laid the mirror on the ground to see the hole...)
HTH [i]
Old Sep 24, 2006 | 10:03 PM
XrayDeltaOne's Avatar
XrayDeltaOne
Make sure you secure them with some lock-tite at the very least. Experience has taught me that the allen bolts alone are not guaranteed to hold them in place.
(I have a spare tip if anyone needs it )
Old Sep 24, 2006 | 10:06 PM
irieman's Avatar
irieman
yes-- i remember your post, and i cringed. and now i try to check my bolts every couple weeks
Old Sep 25, 2006 | 10:24 AM
Justanthony's Avatar
Justanthony
i almost lost mine too
i noticed one of my tips looked misaligned and it had actually come loose. when i tried tightening it, the allen screw just kept spinning. the screw had actually widened the hole that it was supposed to be set in. so basically, i now have to go to a muffler shop and have them welded on. so if you are considering buying these tips, make sure not to overtighten!
Old Sep 25, 2006 | 10:27 AM
Hu99's Avatar
Hu99
They do look better than the original, any change in sound? I would doubt it.
Old Sep 25, 2006 | 09:07 PM
Justanthony
no sound changes. it's just a longer tip. better chance of burning your leg on them while getting stuff out of the boot!
hahahahha!
Old Sep 26, 2006 | 02:36 AM
irieman's Avatar
irieman
been there, done that.
