Interior/Exterior Have a oil pressure gauge? I have a ?
Old Jan 28, 2006 | 12:58 PM
SSMini's Avatar
SSMini
Hello Gents.
Question for ya. I'm shopping around for gauges for the Mini. What kind of oil pressure does the mini produce upon start up? The reason I ask, is the local speed shop sold me a oil pressure gauge for my turbo Cordia and it was only a 100 psi guage (He said that read high enough for me.) and the Cordia upon start up runs VERY close to 100 psi's, give it any gas and its peged out I can either get a 100 psi or 150 psi gauge. If the pressure is anywhere near what the Cordia produces, I will go with the 150 psi gauge.
Thanks....
P.S where is everyone buying there guages??
Old Jan 28, 2006 | 04:19 PM
mini-rolls's Avatar
mini-rolls
I have a oil pressure gauge. On cold start it read 75psi. Not much higher.
Old Jan 28, 2006 | 05:54 PM
SSMini's Avatar
SSMini
Thanks for the reply. If the engine is still a little cold when you take off, does it see 100 psi's?
Old Jan 28, 2006 | 06:40 PM
SSMini's Avatar
SSMini
Are you guys using a Mech. gauge or a Elec. gauge. I wanted to use a elec. guage untill I saw the price $189.95 for the Autometer elec. gauge and only $43.88 for the Mech. gauge......I cant believe the elec. gauge is 4X the price of a Mech. gauge....
Old Jan 28, 2006 | 06:44 PM
kyriian's Avatar
kyriian
im on electrical gauge... at extreme cold startup, tops i see is 5500 kpa... nothing more (i think its 5500, its that or 55000 kpa)
Old Jan 28, 2006 | 06:48 PM
SSMini's Avatar
SSMini
kpa? I guess I have to break out the conversion chart...
Old Jan 28, 2006 | 07:07 PM
mini-rolls's Avatar
mini-rolls
I used the following autometer electrical gauge
http://www.egauges.com/vdo_mult3.asp...ltra-Lite&Cart=
It comes with the sending unit, I built the harness to connect it. It is only three wires; key on 12v power, ground, sending unit. For less than 60.00 it was worth it. I even changed the bulbs to orange and wire them to dim with the dash lights.
Old Jan 28, 2006 | 07:09 PM
mini-rolls's Avatar
mini-rolls
Never gets close to 100psi
TREX
Nov 2, 2019 07:31 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
finn
Aug 21, 2015 07:59 AM
JamJam43087
Aug 16, 2015 02:02 PM
