Interior/Exterior Stone chip repair
Old Oct 25, 2005 | 09:57 PM
Luthier's Avatar
Luthier
Stone chip repair
Hi guys,
I found a kind of big stone chip(about 1 mm dia.) the other day when I washed my MCS.
Do you have any instruction(procedure) to repair stone chip?
I got a Mini's tach-up paint kit already....
Thanks,
Old Oct 26, 2005 | 06:57 AM
jfitzoz's Avatar
jfitzoz
What is a Mini "tach up kit"?
Old Oct 26, 2005 | 10:33 AM
kenchan's Avatar
kenchan
I use a toothpick with the tip flattened (hit your counter top to make the tip flat) and apply the touch up in layers. depending on how deep it its, you may need to do 6-7 layers (coats) or even up to 13 layers like i had to do on mine.
Get the paint so it is slightly convex let it dry for 2 days. Take a
1500 grit and wetsand it so it is at the same height as the surrounding
paint. finish off with a fine compound like ScratchX to polish it up along
with the surrounding paint.
Old Oct 26, 2005 | 10:47 AM
K4KAS's Avatar
K4KAS
He meant, Mini Touch Up Kit.
The steps stated above are perfect. I have also used the new touchup
pens on other cars. Has a brush tip on one side and a ballpoint tip on the other side. Not sure if the Mini colors are avail yet. It works well too.
Touchups take practice. Take your time and dont rush it. Be sure to let it dry for a few days as stated above.
Old Oct 26, 2005 | 12:55 PM
trico's Avatar
trico
You can get the pen here - http://www.autovisuals.com/paintcode.asp
Old Oct 26, 2005 | 08:08 PM
Nuff's Avatar
Nuff
Langka
I've had success with this on other cars:
http://www.langka.com/
Old Oct 29, 2005 | 10:37 PM
Luthier's Avatar
Luthier
It looks great!
I will investigate it and I'm also curious to know how I can handle the clear coat stuff, though.
Happy Motoring!
Old Nov 9, 2005 | 04:30 PM
PDQMINI's Avatar
PDQMINI
Coordinator :: MidCal MINIs
Great Info. Just what I needed!
I went to the autovisuals.com web site & found the code for the BRG Metalic.
But I'm not sure which is the correct White code?
Pepper White?
Any ideas.
Thanks, Robert.
Old Nov 12, 2005 | 09:03 AM
Nuff's Avatar
Nuff
Pepper White?
Any ideas.
Thanks, Robert.
I had a good experience using http://www.paintscratch.com. I had a 1990 911 C2 and bought their spray can kit (basecoat and clearcoat) to paint some new mirrors. It matched perfectly.
Haven't had to paint my MCS yet.
jeri534
Nov 6, 2015 01:40 PM
Fordgt4
Oct 10, 2015 10:42 AM
Samhillrocks
Sep 29, 2015 12:55 PM
The Rossness
Sep 17, 2015 03:06 PM
Sep 4, 2015 03:56 PM
