Interior/Exterior New M7 lower grill installed.
Old Oct 19, 2005 | 10:44 AM
daleCarlsbad's Avatar
daleCarlsbad
The installation is very easy, as taking off the front bumper took about 10 minutes. After you unclip the OEM plastic grill, it is simply a matter of drilling 3 small holes and attaching the new grill, which fits the opening perfectly.
A few other options for a cleaner look is to paint all the aluminum parts behind the grill with high temp black, including the lower section of the crash bar behind the bumper. Also, I cut out the plastic outside air temp sensor mounting bracket and attached this to the lower edge of the crash bar for a secure fit.
I purchased the M7 ultimate Grille from m7tuning.com. This is the identical product from GrillCraft, and it came with their badge attached, which I removed.
My original plastic grill kept popping out of the lower front tab. Once the bumper was off the car, I noticed that this mounting tab was missing the metal clip located on the back side…….as this has been mentioned by others, I wonder how many other Minis are missing this clip?
Old Oct 19, 2005 | 10:58 AM
M7's Avatar
M7
Congrats on that fab looking uppgrade
Yes GrillCraft does make the Grille for M7 (exclusively), and other applications
will be available in the first quarter 06...
peter
Team M7
562-608-8123
Old Oct 19, 2005 | 01:16 PM
Rick-Anderson's Avatar
Rick-Anderson
Looks awesome. I have had mine for about a year now and it still looks new. I also got the rear grills, which I absolutely love!
Old Oct 19, 2005 | 02:06 PM
red rage's Avatar
red rage
How hard is the install? You take off the front bumper and ?
I need one with the tow-hook area cut-out, for track misadventure use
Old Oct 19, 2005 | 02:19 PM
J0kER's Avatar
J0kER
so far this is my favorite body 'mod' on my ride. --that bottom piece in between fog's really sets it off!!!
Old Oct 19, 2005 | 02:25 PM
kalbone's Avatar
kalbone
looks good.
Old Oct 19, 2005 | 03:23 PM
Rick-Anderson
Here is a link to a step-by-step install that I did: http://share.shutterfly.com/action/w...8Aat2jdu2at2Ks
You can cut a circle with a hole saw (with a wood backing for the grill) or wire cutters then use a large rubber grommet for the tow hook.
Old Oct 19, 2005 | 03:42 PM
bee1000n's Avatar
bee1000n
Originally Posted by M7
and other applications will be available in the first quarter 06...
What does "other applications" mean? More grille options for MINIs, or grilles for other kinds of cars?
(I'm still hoping you'll come to your senses and add paintable trim surrounds to your upper and middle front grilles. C'mon we need a metal version of the aero kit grille that will fit a stock MCS bumber without causing a headache!)
Old May 8, 2006 | 07:24 AM
Ranzo's Avatar
Ranzo
Does this fit the Cooper?
Old May 8, 2006 | 09:12 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
only if you have a Cooper S front bumper.....it doesnt fit the normal cooper bumper
Old May 8, 2006 | 10:00 AM
astromini's Avatar
astromini
looks awesome..
Old May 9, 2006 | 06:25 AM
donniebronx's Avatar
donniebronx
i thought the M7 didn't require drilling and what not.
only the AERO kits.
Old May 9, 2006 | 07:31 AM
kapps's Avatar
kapps
You have to drill three small holes in the plastic bumper to hold the grill. Click on the link in my sig and then go the the M7 grill install section to see my install photos. Two of them show the mounting screws pretty well.
Old May 9, 2006 | 07:46 AM
OKeefe's Avatar
OKeefe
M7 vs MOSS
I see that in 05 M7 said they had this grill exclusively
but a grill from the same maker is in the MOSS catalog
are they different?
Old May 9, 2006 | 10:27 AM
sddave's Avatar
sddave
daleCarlsbad,
Sweeeet! I was just getting ready to buy the M7 grills, upper, middle and lower and was wondering about installing the lower. Are you going to install the middle and upper?
bbak11010
Sep 7, 2015 08:08 PM
bbak11010
Sep 7, 2015 08:03 PM
tag1260
Sep 2, 2015 07:42 PM
