Interior/Exterior Finally blacked out belt line
Old Feb 3, 2006 | 12:49 PM
  #151
theresa83's Avatar
theresa83
where to get beltline tape?
hello all....can anyone tell me where can I get the black beltline tape? i've checked the 3M website, but it says it's about 40 bucks. can i find any for cheaper? thanks for the help!
Old Feb 3, 2006 | 03:36 PM
  #152
maxmini's Avatar
maxmini
I used the info which i received from the first post in this thread and ordered it from Terry's. It was about $20 to the door as I recall.
Randy
m7 tuning
Old Feb 3, 2006 | 04:53 PM
  #153
Nuff's Avatar
Nuff
Check my first post. I have a link to Terry's.
Old Feb 3, 2006 | 05:16 PM
  #154
maxmini's Avatar
maxmini
Nuff I never did get a chanceto thank you for the post. I did my car in about 30 min and have done 2 others as well and STILL have tape left ! THANK YOU !
Randy
M7 Tuning
Old Feb 3, 2006 | 06:35 PM
  #155
Nuff's Avatar
Nuff
Randy:
I appreciate it, but no thanks necessary! Isn't that why we're all here? Besides, I got the idea from others on this forum anyway, so I shouldn't get all the credit.
Old Feb 3, 2006 | 11:40 PM
  #156
theresa83's Avatar
theresa83
Duh! I read this post months ago, and went back to it today. I totally didn't look at the post very well. Thanks again.
Old Feb 6, 2006 | 02:55 PM
  #157
Nuff's Avatar
Nuff
No worries. Good luck on the belt line blackout!
Old Feb 7, 2006 | 10:03 AM
  #158
V70R's Avatar
V70R
I just did mine with electrical tape just to see if I liked it - I definitely do, and I'll be doing the 3m tape when I get it.
I posted a few pics in this thread -
https://www.northamericanmotoring.co...ad.php?t=60731
I was wondering how the tape is holding up in car washes and other things from the people who have had it on awhile?
Also, does anyone know what would be involved in getting the actual chrome beltline trim changed to black, so it would be a bit lower maintenance? I'm not looking forward to re-applying tape every year or so -
Old Feb 7, 2006 | 10:13 AM
  #159
Nuff's Avatar
Nuff
I did mine in early October. Having gone through the rainy season and numerous car washes (all hand washes with Zaino) I can safely say that the tape looks the same as it did when it was installed. I think one of the problems with "cracking" people had was due to not removing the clear top layer of the tape. The vinyl itself should last a few years.
That said, I'll let you all know when/if it needs to be redone.
Old Feb 7, 2006 | 10:17 AM
  #160
V70R's Avatar
V70R
Thanks! I'll probably just stick with the tape then. I wish it was available somewhere locally, as I can't wait to put it on!
Old Feb 7, 2006 | 10:30 AM
  #161
Smokey's Avatar
Smokey
Just an idea, find out where your body shops places buy their supplies, I'd be willing to bet that they have a local store that carries a large line of 3m products. I went to all the "parts stores" with no luck, but once I found out where the paint store was, bingo!
BTW, I've had mine on for a few months now and I've been using the lazer wash type car washes and have no problem with any part of the tape.
Old Feb 8, 2006 | 04:12 AM
  #162
V70R's Avatar
V70R
I was going to call around, but I ended up just getting it from the link at the top of the thread - they are in FL so I should have the tape today!
Old Feb 8, 2006 | 04:20 AM
  #163
mbcoops's Avatar
mbcoops
Howdy,
I blacked out the ole beltline a while ago but never got it into this thread. It's the 3m tape - not flat though. I think I would like flat better, but the semi-gloss looks good next to the window and the glossy paint. I can't imagine my car without it now.
Here's the boy:
mb
Old Feb 11, 2006 | 09:28 AM
  #164
Nuff's Avatar
Nuff
Originally Posted by mbcoops
Howdy,
I decided to go with the low-gloss because it matched the rest of the trim. But I doubt it makes that much of a difference. Yours looks great. Plus, for another $20 and 20 minutes, you can change it! You can even try semi gloss red!
Old Feb 14, 2006 | 08:57 AM
  #165
simplygriff's Avatar
simplygriff
Coordinator :: Tar Heel MINI Motoring Club
Edit: Nevermind.... it wouldn't work....
-G
Old Feb 19, 2006 | 07:50 AM
  #166
rotomstel's Avatar
rotomstel
Every ones cars look great!!! Ijust ordered up my tape from terry's. I can't wait to give this a try, and for 20 bucks whats to loose
Old Feb 20, 2006 | 09:10 AM
  #167
simplygriff
Did mine this weekend... Thanks for the help, and tape TWISTER! :D Anyone know an easy way to pull off the protective clear strip? The gloss is just sticking out too much for my taste.
-G
Old Feb 20, 2006 | 09:17 AM
  #168
V70R's Avatar
V70R
In my opinion, you HAVE to remove the clear strip, as it will start to crack and look really nasty if left in the sun for a few months or so. I cut my sections of tape about 2" longer than needed - I adhered the tape to the car, then worked the clear top layer loose with a razor blade, then pulled it off the section I was working on. I then used the razor to trim the tape so it would sit perfectly at the end of each section, right at the endcap. I actually used the endcap as a razor guide. Be careful not to let the razor slip though - you will scratch your paint. I held a towel just below where I was trimming the tape to protect the paint.
If you've already trimmed the tape, it will be difficult to get the clear layer off without damaging the black vinyl layer - you could peel a corner off, then try and get a razor in there to work the clear layer loose. It's not easy. Good luck!
Old Feb 20, 2006 | 09:27 AM
  #169
simplygriff
Crap... I'm going to have to re-do the front anyway so I'll know for that piece. I could probably trip up some of my other edges better too so maybe I can use what little excess I have to get that strip off. Thanks for the tips V70R.
-G
Old Feb 20, 2006 | 09:34 AM
  #170
Spikedacrzyman's Avatar
Spikedacrzyman
Where can i go to order that tape? I am dieing to Black out the belt. I hate chrome... Thanks for the help guys.. Spike
Old Feb 20, 2006 | 09:36 AM
  #171
simplygriff
Originally Posted by TWISTER
I got my PROSTRIPE vinyl from Beacon Graphics.
http://www.beacongraphics.com/prostripe.html
1/2 inch x 150 feet $13.24
This is what we used this weekend. I'm going to order some for myself.
-G
Old Feb 20, 2006 | 09:41 AM
  #172
ScuderiaMini's Avatar
ScuderiaMini
yeah, pull that clear coat off after you do the line, it will look much better and last longer
Old Feb 20, 2006 | 09:54 PM
  #173
COR BLMY's Avatar
COR BLMY
MBCOOPS
Thanks for posting a photo of your CR "black out"
Looks great... thats next on my list
Oh and the blacked ot BLACK combo is AWESOME
Old Feb 20, 2006 | 09:56 PM
  #174
COR BLMY's Avatar
COR BLMY
Originally Posted by Nuff
This was much easier than I thought. I used 1/2" 3m low gloss black vinyl tape from Terry's Auto Supply. It was $17.59 for a 150' roll. The low gloss black is a great match to the rest of the trim.
Apply the tape slowly and make sure you don't stretch it too much. I used an Xacto knife to cut the ends off. Take your time when you go around the turns at the corner of the car (A pillar and C pillar).
Here's how it turned out:
I got a set of stock black side vents and I'm going to paint them body color and install black side marker lights from Out Motoring.
Still need to tint the windows and get some wheels .....
Your blacked ot ride is beautiful...
ever thought about black wheels
Old Feb 20, 2006 | 10:20 PM
  #175
Nuff's Avatar
Nuff
Thanks.
That was an old photo. I've since added black ASA AR1s (black w/polished lip).
