Interior/Exterior CravenSpeed Rally Light Kit
Old May 3, 2019 | 11:44 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
Hi everyone. Just wanted to show you guys our new Rally light kit for the F56. We couldn't afford the OEM kit, so we thought we'd put something together ourselves. We've partnered up with a relatively small and unkown local company called PIAA to produce an affordable yet very high quality kit:
The kit includes two brackets that attach to the v-brace right behind the grill. The brackets use a two-piece design. The light tabs are stainless steel and the dogbone clamps are aluminum. Both get powder coated with a black textured finish:
We chose to use the PIAA LP550 for our lights. These are a very bright, high quality LED light produced by one of the most reputable companies in the business.
It comes with everything you need to install the lights, including the brackets, the lights, wiring etc...
The install is pretty easy, Steve has written some nice guides here:
F56 https://www.cravenspeed.com/f56-auxi...-instructions/
F60 https://www.cravenspeed.com/f60-auxi...-instructions/
If you've got something else in mind for lights we've got the brackets available separately here:
F56 https://www.cravenspeed.com/rally-li...f56-2014-2019/
F60 https://www.cravenspeed.com/rally-li...f60-2017-2018/
And a Countryman F60 kit here: https://www.cravenspeed.com/rally-li...f60-2017-2018/
Let me know if you have any questions!
-Logan@CravenSpeed
Old May 3, 2019 | 12:01 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
If I have the MINI halogen versions, what is involved with a retrofit? Can I just replace the lights themselves using all existing brackets and wiring? (easy).
Old May 3, 2019 | 02:37 PM
CravenSpeed
Vendor
Not sure I am following you?
Old May 3, 2019 | 02:45 PM
Minnie.the.Moocher
Can I just use the light body with led bulb in place of existing halogen MINI branded units. Without having to install all the other wiring, brackets, relays, etc.
Old May 3, 2019 | 03:16 PM
CravenSpeed
Vendor
The PIAA Lights come with their own wiring harness, but I am sure you could connect them to your existing wiring. I don't know what the OEM brackets look like. You could take a look at our install guide to see if the PIAA lights are compatible:
Old May 3, 2019 | 05:46 PM
vetsvette's Avatar
vetsvette
Moderator
Very nice setup. Nice of y'all to give the nod to that small local company.
Old May 4, 2019 | 07:40 PM
SFMCS's Avatar
SFMCS
Nice. Had PIAA's on my '03. Tempting but looking to put smaller rectangular ones right under the bumper, on the sides, over that little blank spot.
Old Jul 18, 2020 | 03:03 PM
jpsjr1970's Avatar
jpsjr1970
I just bought a ‘15 JCW will these fit? Also how hard to install with the PIAA lights? Very Interested! Jose
techtipz
Dec 13, 2013 06:58 AM
LJGeist
Jul 30, 2013 06:28 PM
bmwbrandon
Mar 8, 2013 07:48 PM
Eric5279
Jan 4, 2012 01:59 PM
BradB
Oct 22, 2003 09:30 AM
