Interior/Exterior HID Upgrade
Old May 9, 2017 | 03:56 PM
Countryman97s's Avatar
Countryman97s
HID Upgrade
Hi i have a r60 without the HID headlights but i want to get the f60 HID retrofit ones on ECS Tuning. is there an adapter to fix this? Thanks
Old May 9, 2017 | 04:42 PM
808keith's Avatar
808keith
Are you talking about these:
Should be plug n play but they're not HID but LED.
Countryman97s
Yes i am!
Old May 9, 2017 | 04:43 PM
Countryman97s
The top part is led not the main headlight
Old May 9, 2017 | 04:57 PM
808keith's Avatar
808keith
yes and the headlights are projector halogens, H9 bulb type. Not HID.
Old May 9, 2017 | 04:58 PM
Countryman97s
Ohhhhhh ok looked like HID from the photos thanks!
Old May 9, 2017 | 04:59 PM
808keith's Avatar
808keith
You need the Bi-Xenon Headlight 25W set. That's the retrofit HID kit from Mini or fabricate your own.
But you'll need to get your car coded to run HID otherwise it won't work.
Old May 9, 2017 | 05:02 PM
Countryman97s
Wait so i cant do the ones you just posted? I see the 25w set but they are not the same
Old May 9, 2017 | 05:03 PM
808keith's Avatar
808keith
only if you upgrade to the 25W set which are true bi-xenon HID will you have to get your car coded to run those. Those other ones I posted are plug-n-play.
Old May 9, 2017 | 05:04 PM
Countryman97s
Oh ok Thanks for the clarification!
Old May 12, 2017 | 07:40 AM
+1 there are two main options.
https://www.northamericanmotoring.co...r-r60-r62.html
Halogen => Bi-Xenon factory retrofit
And the new Sonars in black or chrome.
Halogen => Bi-Halogen projector with LED DRL ring on the outside. They take H9 stock bulb and have a flap on the inside that moves for the high and low beam. Some people take xenon retrofit H9 kits and use them in these. We dont carry those retrofit xenon kits for stock H9 bulbs. And that way they convert them to xenon.
https://www.ecstuning.com/News/MINI_R60_R61_Sonar_Projector_DRL_Headlights_24111/
Thats to two main options.
