Interior/Exterior Removing the "Cooper" badge (2010 MCS)
Old Feb 22, 2017 | 01:54 PM
Ketchup's Avatar
Ketchup
Hi all.
I was thinking about removing the "Cooper" badge from the rear and putting the "R56" badge in its place. https://www.waymotorworks.com/r56-ch...ter-badge.html
How difficult is it to remove that being that it's 7 years old? ...and how would one remove it? Is is double stick taped on or an actual bolt-on badge?
Thanks!
Old Feb 22, 2017 | 03:03 PM
Fly'n Brick's Avatar
Fly'n Brick
Very easy. Dental floss. Get it started at a corner and pull it back and forth like a saw. Any adhesive left behind can be removed with WD-40.
Old Feb 22, 2017 | 05:00 PM
DneprDave's Avatar
DneprDave
I took the "cooper" off with my fingernails on a hot summer day. A hair dryer would help soften the sticky, if you don't have a hot day.
Old Feb 23, 2017 | 05:48 AM
Ketchup's Avatar
Ketchup
Sounds easy enough! Thanks!
Old Feb 23, 2017 | 10:19 AM
drewstermalloy's Avatar
drewstermalloy
Use a hair dryer or a heat gun to soften up the adhesive. If you don't it'll take you a lot longer to get it off.
Old Mar 1, 2017 | 05:48 AM
Ketchup's Avatar
Ketchup
I got my "R56" badge last night. Probably going to do this on the weekend. Anything I should do for "surface prep" before attaching besides cleaning the area well?
Old Mar 1, 2017 | 06:29 AM
Fly'n Brick
Nope. Just make dang sure you've got it EXACTLY where you want it before you pull off the tape. I used painter's tape around the area then taped down the badge and eyeballed it then used a straight edge marking the blue tape for reference then laid it on. It's all in the preparation.
Old Mar 1, 2017 | 08:35 AM
Ketchup's Avatar
Ketchup
Thanks! I plan on doing just that. If it's even the slightest bit crooked it will **** me off to no end.
Old Mar 1, 2017 | 10:23 AM
Fly'n Brick
When you get it done, as one of the old timer's herein was want to say: "Pictures, dammit, pictures. Without pictures, it didn't happen."
Old Mar 1, 2017 | 01:09 PM
dkdzyn's Avatar
dkdzyn
I did the same with mine. I'm VERY happy with the result.
Attached Thumbnails Removing the "Cooper" badge (2010 MCS)-r55s-emblem.jpg   Removing the "Cooper" badge (2010 MCS)-back-of-stitch.jpg
Old Mar 1, 2017 | 01:14 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I know there are no locating pin holes behind the "Cooper S" badges... Are there any locating holes behind the "Mini" wings badge? I'd like to clean up the doors of my Clubman.
Old Mar 1, 2017 | 01:35 PM
buzzsaw's Avatar
buzzsaw
May want to spray a little paint friendly dish soap on the area to clean off any wax residuals for a solid adhesion.
Old Mar 1, 2017 | 02:30 PM
DneprDave's Avatar
DneprDave
I changed out the "C" in Cooper to a "P".
Old Mar 1, 2017 | 02:40 PM
Fly'n Brick
Hot dog, I've still got the letters when I replaced that badge after installing boot stripes. I've got to think about that.
Old Mar 1, 2017 | 03:48 PM
isamin's Avatar
isamin
I removed the "wings"from my rear hatch and sold it. I moved my JCW badge to the former position of the "wings" which fit perfectly. Next I added a Chevy Aveo TURBO where the JCW badge formerly resided and on the front I removed the "wings" and replaced with a GEN I JCW (cloisonne) badge. It's the little things that count. See it at MOT2017.
ISAMIN
Old Mar 4, 2017 | 01:37 PM
Ketchup's Avatar
Ketchup
Oh, it happened!!
Coop!
Just an "S" ...
They look lined up ...
Crap! Really?! The flipping "R" is a bit lower. Going to have to fix that!
Thanks for the help!
Oh, if you don't have floss, use a little more heat & "quadrupled" sewing thread.
Old Mar 9, 2017 | 06:39 PM
Tommy Kardinal's Avatar
Tommy Kardinal
I have a non-s and I'm considering just getting rid of the COOPER altogether. Wonder if it would have a 'tan-line' or something since I have a pepper white.
Old Mar 9, 2017 | 06:49 PM
Ketchup's Avatar
Ketchup
Only if the paint was really faded. After removal, it does leave a "dirty mark", but it cleaned off really easy. (See the first "dirty" & second "cleaned" pics.)
I do have that issue with the iron flakes in the paint. Going to have to get that IronX remover:
Amazon Amazon
Have fun!
Old Mar 9, 2017 | 08:59 PM
Fly'n Brick
Bravo Zulu!!
(that's Navy talk for well done)
