Interior/Exterior Rolled Rear Fenders
Old Sep 24, 2004 | 10:57 AM
rts's Avatar
rts
Rolled Rear Fenders
I cant' find any info of anyone rolling their rear fenders to make more tire clearence. Has anyone tried this old school method on a Mini. I'm on the verge of borrowing a roller and could use some advise. I've already done all the triming possible to the plastic flair and need about about 3/4" to 1" more clearence.
Thank in advance
RTS
Old Sep 24, 2004 | 12:32 PM
minie's Avatar
minie
i don't think u can roll the rear fender, as the mini have plastic fender. mini owner do trim out part of the inside trim plastic to stop rubbing
Old Sep 27, 2004 | 03:29 PM
rts's Avatar
rts
Update Rolled Rear Fenders
As an update on rolled rear fenders over the weekend I had a chance to try the roller. The roller arm is attached to rear rotor hub, and can be infinnally adjustable, from length,height, and angle of roller. As you apply pressure,and roll back and forth the fender does flex, almost enough to scare you that everything is ruined. But no damage so far, I've been able to pushout the backhalf about onehalf inch (1/2 ") and tapper the front half as though never moved. I still haven't reach my goal of ( 1" ) wider fenders.
You can see I'm still looking for help!!!!
Can one go the extent as to drill out the spot welds on the second-inter fender, therefore become separate of the outer body and then push more??
Then after all is set as to the width I want, Then reshape the second-inter fender and spot weld.
RTS
Old Sep 28, 2004 | 05:45 AM
MSFITOY's Avatar
MSFITOY
Pics?
Old Sep 28, 2004 | 11:13 PM
SteelKite's Avatar
SteelKite
Yeah ... we're definately going to have to see pictures of this one.
It's almost like an accident that you can't look away from !
Just kidding Please post!
Old Sep 28, 2004 | 11:45 PM
XAlfa's Avatar
XAlfa
For the love of God, STOP!!
Old Sep 29, 2004 | 12:05 AM
CooperSdriver's Avatar
CooperSdriver
I would definitely like to see pics. There is a show car, I think MINI Mania was involved with, that was widened by 1 inch at least. I'll try to find the pics to post.
Danny
Old Sep 29, 2004 | 12:13 AM
CooperSdriver
This was at the "2004 Spring Thing" in Orlando. The owner lives in Miami, hes the guy that installed the sound system on my car, and we've become good friends. The mod list is extreme, down to a full custom turbo kit. Its hard to see the fenders, but it gives you an idea. I'll ask him to see how he did it.
Danny
Old Sep 29, 2004 | 10:53 AM
rts's Avatar
rts
2nd Update Rolled Rear Fenders
Sorry! on pictures to post as you all requested.
The end results are not really visable, the plastic flair seems to hide all the rolling I did. The further I got into the job I realized that there is actually five (5) thickness that one must actually roll/ cut: (1)-bracket for plastic flair (2)- cut 1/2" and roll main body panel (3)- roll inter-steel fender together with main body panel (4)-cut-trim plastic fender liner. (5)- and naturally one must trim the inside lip of the plastic flair.
I didn't go the route of drilling out the spot welds cause with all the rolling the plastic flairs just barely line up with the trim of the rear bumper,
so I quit!
End results is I only gained 1/2" of width / depth per side.
Would I do it again? probably not, I just raise the height.
BUT I STILL LIKE THE LOOKS !!!!!
Thank,
RTS
Old Sep 29, 2004 | 05:54 PM
d6-mcs's Avatar
d6-mcs
I DID IT, I rolled my rear fender with a BASEBALL bat.
chris
Dec 23, 2015 10:36 AM
makg
Aug 21, 2015 02:49 AM
Chippawaguy
Off-Topic :: Autos
Aug 19, 2015 11:30 AM
bctf1
Aug 6, 2015 12:55 PM
