Interior/Exterior Aero side skirt install how to?
Old Nov 25, 2015 | 07:56 AM
TISGOD's Avatar
TISGOD
Anyone who upgraded to aero side skirts happen to have a "how to" write up?
I looked around but haven't seen anything.
Would just like to have an overview of the process before I dig in (replacing my stock side skirts with aero).
Thanks!
T
Old Nov 25, 2015 | 08:37 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
The R53 side skirt is held on by clips, which you can see from the diagram below. Just be sure to remove those and you should be able to pop it off. The JCW side skirt should be the same and snap into place with clips and rivets. (Hopefully it came with the mounting hardware required).
888.280.7799 | 6am - 5pm PST
Old Nov 25, 2015 | 09:13 AM
TISGOD's Avatar
TISGOD
Perfect! Thank you!
It's a brand new kit so came with everything.
I see you'd probably have to peel up the "Cooper S" door sill, Does this mean I will need new sills?
Old Nov 25, 2015 | 09:24 AM
PelicanParts.com
Vendor
Originally Posted by TISGOD
Perfect! Thank you!
You're welcome. The door sill is on there with an adhesive. You may be able to reattach it when you're done with a spray on adhesive or a type of adhesive tape (like 3M). If yours is in good condition that is the route I would go instead of buying a new door sill. Otherwise, if you want to replace it we have them here.
Old Nov 25, 2015 | 09:30 AM
TISGOD's Avatar
TISGOD
Excellent, I'll order from you if I cant reattach mine. I have a small ding in my passenger side sill from a mic stand, so I'll probably be replacing that anyway.
I really appreciate your help.
Old Nov 25, 2015 | 09:39 AM
PelicanParts.com
Vendor
Sounds good. You're very welcome and if you need anything else be sure to let me know.
Old Nov 25, 2015 | 11:06 AM
rkw's Avatar
rkw
From a 20 second Google search: http://www.motoringfile.com/howto/Ae...%20Bodykit.PDF
Old Nov 28, 2015 | 04:52 AM
TISGOD's Avatar
TISGOD
Originally Posted by rkw
20 seconds? BOY did you make me fell like a lazy slug.....
Not really.
Thanks.
okeyes
Navigation and Audio
Jun 26, 2019 04:43 PM
goneFXcrazy
Jul 8, 2016 12:34 PM
y8s
R60/R61 Stock Problems/Issues
Dec 3, 2015 06:05 AM
ChineseBandit
Tires, Wheels, & Brakes
11
Nov 25, 2015 06:10 PM
