Interior/Exterior Crazy idea- Custom rook rails
Old May 10, 2014 | 11:50 PM
ImThaBean's Avatar
ImThaBean
OK, so I installed the factory rook rack on my R53 and I have enjoyed having it on there. I have big plans for utilization but have not been a big fan of the constant whistling from the end caps. or how the roof looks when the rack is not on (screw covers).
I have a weird idea, have some custom rails fabricated that will mount to the stock locations and use Thule or Yakima cross bars. This way, I can take the cross bars off, when not in use (damn you whistle & drag) but the rails stay in place and give a clean look compared to leaving the rack on or using the screw covers. Think Countryman
To give you an idea of what i'm talking about, the thought came after seeing a few Nissan Frontier/Xterra's with factory racks as I drove around L.A. today.
This is either gonna be awesome or horribly horribly bad. Either way, I need to find a welder/fabricator.
Old May 12, 2014 | 07:32 AM
thirdlobe's Avatar
thirdlobe
Sounds like a neat idea. I was never for the drill into my roof for the factory rails so I went with Yakima for several reasons.
Excited to see if this gets going.
Old May 12, 2014 | 11:36 AM
ImThaBean's Avatar
ImThaBean
I wasn't too fond either. Just couldn't resist after the deal I got on the OE rack. So now I'm back peddling and trying to find a way to hide the holes. This is the best way I found.
I'm going to look at a rack today. So once I get that. I can get some measurements and start looking for a welder.
Old May 14, 2014 | 05:56 PM
ImThaBean's Avatar
ImThaBean
Here is a test run using the factory Mini rack as the cross bars. I am looking into material options for the rails and mounting.
Old May 15, 2014 | 06:27 AM
Saltysalt's Avatar
Saltysalt
PS i love that sticker, and those rails are looking good! what are those rails from? and youll need some end caps cause i bet those will whistle hard!
Old May 23, 2014 | 10:38 PM
Jacob.R50's Avatar
Jacob.R50
i think your trying to fix the wrong thing. i have a roof rack as well, mine was whistling. i made a fairing and now it no longer whistles. try a fairing on the OE rack.
here is a picture of mine now
Old May 24, 2014 | 06:29 AM
ImThaBean's Avatar
ImThaBean
In reality, the whistling isn't the biggest issue. I have made the fairing. It helped get rid of the whistling for the most part. but it didn't solve my biggest problem. The fact that I have these huge bolt heads on my roof. I have been fine tuning my roof rail search and think I may have found a viable solution. The Nissan tube rail thing is just too bulky/ large diameter tube to sit right on the mini. I recently bought a set of roof rails from a chevy suburban that may do the trick. It sounds crazy, but im my head, it works. Stay tuned for updates.
Old May 25, 2014 | 11:43 AM
Jacob.R50's Avatar
Jacob.R50
good looking car, and i love the plates
here is mine
Old May 25, 2014 | 08:07 PM
ImThaBean's Avatar
ImThaBean
I bet them beemer boys aren't too fond of your plate. haha
Old May 30, 2014 | 06:14 PM
hunter99's Avatar
hunter99
MINI actually makes/ made a set of rod rails for the R53. Flow MINI of Winston Salem ordered them and installed them on a car. Not too bad looking. If I remember right they used the factory roof rack and it screwed into an piece on the rail. This allowed it to be adjusted front to rear. I also remember, could be wrong, that is used the same mounting points as you do if you mount the roof rails directly to the roof.
Old May 30, 2014 | 06:54 PM
ImThaBean's Avatar
ImThaBean
My jaw dropped after reading that. I looked and I have found this. Of course..... Now to see if I can find all the discontinued parts they used...
Old Jun 1, 2014 | 12:41 PM
chris.j.lamb's Avatar
chris.j.lamb
here you go........ http://www.realoem.com/bmw/showparts...26&hg=82&fg=51
OutMotoring
Mar 3, 2017 06:29 AM
NYMADMINI
Dec 14, 2016 02:33 PM
Fordgt4
Oct 10, 2015 10:42 AM
Emnotek
Sep 29, 2015 07:37 AM
