Interior/Exterior Remving Bonnet Stripes - My Experience
Old May 2, 2014 | 03:11 PM
bcman's Avatar
bcman
I bought an '08 MCS a little over a year ago, Lazer Blue with white bonnet stripes. They were getting scratched and dingy, so I decided it was time for them to go. After 5 years out in the SoCal sun, the vinyl was so brittle that it chipped off in tiny pieces rather than peeling. I spent about 2 hours with a heat gun in one hand and the other picking and peeling, and got about 3/4 of one side off. I searched the forums, and bought two products recommended here:
plastic razor blades plastic razor blades
and
3M adhesive remover 3M adhesive remover
. For the 3M remover, first I decided to test it on the paint in my engine bay. sprayed a bit on, wiped it off, and the paint thinned out to where I could see bare metal, and the rag turned blue. No Thanks! Next up I tried the razor blade, and it worked great! I waited for a hot day, and went out during my lunch hour, and got the remaining 1 1/4 stripes up in a half hour. I did manage to wear out one of the two blades in that time, though, so if you have a big job I would recommend buying extra blades.
Old May 14, 2014 | 05:34 AM
wrf's Avatar
wrf
How was the paint beneath the stripes?
I've got an '07 MCS but have been hesitant to remove the strips for fear of a paint differential due to the paint beneath the stripes being protected.
Old May 14, 2014 | 09:08 AM
N2MINI's Avatar
N2MINI
yeah, lots of times it not so much that the paint has faded some, ( paint and clear coat has come along ways ) it's that the paint under the stripes has no scratches at all.
Old May 14, 2014 | 10:30 AM
v10climber's Avatar
v10climber
The guys that do vinyl for a living use vinyl erasers that will chuck up in a hand drill. They're made of rubber and take the vinyl right off without damaging the paint underneath. I've used one to remove a lot of 7 year old vinyl off a race car and it worked great although required a lot of hand strength to keep it from skipping all over the place. Obviously the professionals have bigger/better ones...
Old May 14, 2014 | 10:44 AM
Capt_bj's Avatar
Capt_bj
What color? Some colors are more susceptible to fade. Metallic reds and metallic dark greens can be a problem. Black, white, solid blues, silver, not much problem.
Does the car live outside in the sun all the time, or is it garaged?
Old May 14, 2014 | 11:25 PM
rhygin's Avatar
rhygin
Agreed. Did my dark silver 2007 last summer using a plastic blade and some goo remover.
The paint underneath was totally perfect, so the lines were visible at first. But the paint was unfaded and a clay bar and polish made everything look near perfect.
Old May 15, 2014 | 05:40 AM
wrf's Avatar
wrf
My car is the metallic British racing green. The strips are starting to crack a bit. The car is new to me, so I have no idea if it was garaged.
Sounds like I should be prepared to replace the strips if I remove the old ones.
Thanks for the info!!!
Old May 28, 2014 | 12:16 PM
bcman's Avatar
bcman
Not too bad, but definitely noticeable:
It's an '08, Laser Blue Metallic. I've had the car for one year now, it spends most days out in the Southern California sun. I knew it wasn't going to be perfect. It looked a lot worse right after removal. Clay bar, polish, and wax helped a bit.
Old May 28, 2014 | 12:24 PM
bcman's Avatar
bcman
https://www.northamericanmotoring.co.../small/cat/500
Old May 28, 2014 | 02:50 PM
RB-MINI's Avatar
RB-MINI
Originally Posted by bcman
... For the 3M remover, first I decided to test it on the paint in my engine bay. sprayed a bit on, wiped it off, and the paint thinned out to where I could see bare metal, and the rag turned blue. No Thanks! ...
MINI's don't seem to be clear coated under the hood, and in the jambs, except for the doors Even a mild cleaner like diluted simple green will remove the paint in those areas.
Old May 30, 2014 | 06:07 PM
bcman's Avatar
bcman
Good point, RB. I thought that might be the case, but wasn't willing to risk it. The plastic blade was gentle enough.
Boverphoto
Jul 3, 2017 10:56 AM
Moya45
Nov 2, 2015 04:16 PM
Olenska
Sep 21, 2015 12:36 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
Norton70
Sep 7, 2015 05:06 PM
