Interior/Exterior X5 Fog Lights on an R56
Old Feb 6, 2014 | 01:20 PM
kacken's Avatar
kacken
Hey there,
Does anyone know if these OEM X5 Fog Lights will fit on an R56. I figure even if I have to do a little finagleing with electrical, housing, etc. for $60 it wouldn't be that bad of an option. Any ideas or suggestions would be appreciated.
http://www.theretrofitsource.com/clo...l#.UvP3_mJdUik
Thanks!
Old Feb 6, 2014 | 02:16 PM
mikeson's Avatar
mikeson
I want to put one on my R53.
Nice find.
Old Feb 6, 2014 | 02:18 PM
llewellyn's Avatar
llewellyn
Funny, I saw these on there last week and I was wondering the same thing.
Old Feb 7, 2014 | 05:34 AM
kacken's Avatar
kacken
From what I'm told from TRS it looks like they may not work. Although if anyone tries it I'd be interested in knowing how it goes.
Old Feb 7, 2014 | 09:22 AM
ammodave's Avatar
ammodave
Compare the shape and depth of the housings. I don't believe you'd ever get them to fit in the oem position particularly on the left side where the windshield washer bottle is right behind the fog light. Only way to find out for sure is to buy a pair (check their return policy first) and do some brainstorming.
Old Mar 6, 2014 | 11:04 AM
VoodooJC's Avatar
VoodooJC
I bought a pair from them and will try to attempt a retrofit in the next week or so. I tested the lights out and the throw is super wide and very bright. Hope I can get it to work! Will update when/if I get them installed.
Old Mar 15, 2014 | 06:39 AM
VoodooJC's Avatar
VoodooJC
Took off my bumper last night and attempted to install the X5 fog lights. The light fits perfectly in the hole, but none of the bracket holes line up. Also, the polarity of the oem plug is reversed so I had to dremel out the middle of the connector to install the plug 'backwards'. I was able to zip tie the fog light onto the bumper, but will see if I can come up with a better solution. It's not a heavy piece so zip tie should hold fine. Pics later!
Old Mar 15, 2014 | 09:18 AM
ammodave's Avatar
ammodave
The oem fogs have adjusting screws to aim the fog lights to prevent blinding oncoming traffic. How are you going to fine tune the aim using zip ties? Have you considered fabricating some custom mounting brackets out of sheet metal to use the oem mounting holes?
Old Mar 15, 2014 | 09:53 AM
VoodooJC's Avatar
VoodooJC
The X5 fog lights have adjustments in it to fine tuning up and down too. It rotates the reflector inside the housing. I thought about sheet metal but I'll give zip ties a try first.
Old Mar 15, 2014 | 06:49 PM
VoodooJC's Avatar
VoodooJC
I hooked the X5 LED fog lights up to the parking lamps and it works initially, but then starts flashing. I added a 194 bulb in parallel on each side and they still flash. Looks like I'll have to wire them up with a relay harness.
Old Mar 15, 2014 | 06:53 PM
VoodooJC's Avatar
VoodooJC
Some pictures of the install.
Old Mar 16, 2014 | 05:50 PM
M'Cooper's Avatar
M'Cooper
This is very interesting. Did you get them to work correctly?
Old Mar 17, 2014 | 04:32 AM
VoodooJC's Avatar
VoodooJC
Not yet. I just got my NCS Expert cable so maybe disabling the bulb out check will fix the problem. Time to start learning how to use NCS Expert!
Old Mar 17, 2014 | 06:51 AM
yetti96's Avatar
yetti96
+1 for TRS and trying to make it work. Keep us updated.
Old Mar 21, 2014 | 05:13 PM
M'Cooper's Avatar
M'Cooper
Any update?
Old Mar 23, 2014 | 07:35 AM
VoodooJC's Avatar
VoodooJC
Haven't had time to mess with it. I got my NCS Expert cable, but it wasn't able to communicate with the car. Will try again later when I have time.
Dec 23, 2015 10:36 AM
Zettinger
Aug 25, 2015 04:04 PM
FLYM1N1
Aug 15, 2015 11:20 AM
