Interior/Exterior ScanGauge E vs ScanGauge II
Old Dec 29, 2013 | 06:05 AM
johnvanrees09's Avatar
johnvanrees09
There are a lot of posts about the individual ScanGauges on here but no one has really said what one they like better or which one is the best. (unless my searches have missed something)
I'm leaning more toward the ScanGauge II because it has so many more features then the ScanGauge E, however the fuel economy features on the E also make it very tempting.
Its not a matter of if, more a question of which one...
Anyone have any input on these products?
Maybe WMW could offer some suggestions?
Old Dec 29, 2013 | 06:48 AM
bavmotors's Avatar
bavmotors
I believe the gauge 2 is better in every aspect except price
Old Dec 29, 2013 | 07:04 AM
jkapinos's Avatar
jkapinos
Get the Scangauge II and make sure the mini software is loaded before you purchase.
Old Dec 30, 2013 | 07:10 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the ScangaugeII is 10x more popular than the E. The ScangaugeII does have a few fuel mileage functions, but it also displays 4 gauges at a time rather than just 2 like the E. The 2 also gives you the ability to add new features as they come avail. or for updates.
Old Dec 30, 2013 | 09:21 PM
vetsvette's Avatar
vetsvette
Moderator
If you buy a used one or one that hasn't been programmed for Mini, they will update it for you at no charge. It'll just cost you the postage to ship it to them.
Old Dec 31, 2013 | 12:52 AM
Eric_Rowland's Avatar
Eric_Rowland
Is there a thread that details what the 'MINI software' enables?
Old Dec 31, 2013 | 05:31 AM
bmwr606's Avatar
bmwr606
hi Eric
i just purchased a scangaugeII w/mini software
an extra sheet comes with that says
"additional mini gauges
TFT - Automatic trans temp
EOT - oil temp
A/F - air to fuel ratio
FRP - Fuel rail pressure
ENG - engine temp"
scott
Old Dec 31, 2013 | 06:50 AM
putttn's Avatar
putttn
bmwR606, I have purchased two units and don't believe I ever got the extra instructions. Does anyone know if they are available online?
Old Dec 31, 2013 | 07:24 AM
bmwr606's Avatar
bmwr606
no need, what i posted is all that is on the extra sheet, no other instructions at all
if you have a unit with the mini customization, these extra gauges show up as you scroll thru the available gauges
scott
Old Jan 1, 2014 | 09:57 PM
Eric_Rowland
Originally Posted by bmwr606
hi Eric
EOT - oil temp
ENG - engine temp"
scott
EOT?! That's worth sending it in for an update. I had know idea there was an OEM sensor for oil temp. I wonder if that's just for the newer cars. Guess I'll contact scangauge. Thanks for the info.
Old Jan 2, 2014 | 04:51 AM
danjreed's Avatar
danjreed
FWIW, EOT = The same as Coolant Temp
FRP = Zero on mine. Does not work.
But having the Oil Temp along with Coolant Temp = Very much worth it..
(I also keep Volts up, and Instant MPG)..
Along with the Craven Speed mount, its a nice setup.
Old Mar 26, 2014 | 11:39 AM
TonyB's Avatar
TonyB
Hi Eric. Long time...
Did you contact SC? I'm under the impression that those updates referenced above are not for our first gen MINI's, and its protocol. If I'm mistaken, please let me know as I wouldn't mind oil temperature. I already have it via an Autometer gauge though...
Old Mar 26, 2014 | 02:31 PM
PrplPplEtr's Avatar
PrplPplEtr
That just means it has the capability of displaying oil temp IF the data is provided (like in 2nd gen). Unfortunately there is no oil temp sender in the 1st gen so no joy unless you fit an aftermarket oil temp sender.
Sent from my Moto X using NAMotoring
Old Jun 20, 2014 | 09:25 AM
TomFarin's Avatar
TomFarin
Gen 1 Factory Gauge Package
My Gen 1 has the gauge package (where the large speedometer normally is). It has oil temperature, oil pressure and water temperature along with the fuel gauge.
So the Oil Temperature sender part has to be available for the Gen 1s.
Old Jun 24, 2014 | 04:09 AM
chris.j.lamb's Avatar
chris.j.lamb
the gauge package makes up the oil temperature from the coolant temperature, there is no separate sensor...........
shorenetworks
Nov 4, 2019 06:18 PM
Jon L
Apr 1, 2010 09:13 AM
