Interior/Exterior Changing fog light wedge 194 bulb and got an error
Old May 18, 2013 | 06:28 PM
sirr6's Avatar
sirr6
I just replaced the 194 wedge bulbs in my fogs lights and got an error, my friend that has a couple BMW's said I would get an error if there cheap bulbs. Is that true? Has anyone else got the exclamation when changing the 194 bulb in their fog lights?
Old May 18, 2013 | 06:38 PM
danjreed's Avatar
danjreed
Are you sure they are 194s? That does not sound right for a fog light.
I thought they were H8s.
Old May 18, 2013 | 06:39 PM
sirr6's Avatar
sirr6
Yea it's the top bulb not the h11
Old May 18, 2013 | 06:45 PM
MIminiclubman's Avatar
MIminiclubman
FOD - Military term for Foriegn Object Debris. Not good for jet engines or your turbo.
The bulb Check is looking for resistance on the circuit. A bulb with less draw, like LED can trip it. If they are LED you need to add a resistor.
Old May 18, 2013 | 06:48 PM
danjreed's Avatar
danjreed
Truth, a LED setup without a load (resistor) inline will trip it.
Old May 18, 2013 | 06:51 PM
sirr6's Avatar
sirr6
Thanks guys, guess ill put the stock ugly colors ones back on, any led's out there that wont cause the trip?
Old May 18, 2013 | 07:07 PM
danjreed's Avatar
danjreed
Just get/install a load equalizer in parallel with the lighting circuit.
Or run one of these that has it built in.
http://www.superbrightleds.com/morei...se-tower/1129/
Old May 28, 2013 | 02:12 PM
ryanschram's Avatar
ryanschram
or remove the bulb checks with coding.
Dec 23, 2015 10:36 AM
AZN Optics
Aug 16, 2015 11:52 PM
FLYM1N1
Aug 15, 2015 11:20 AM
