Interior/Exterior Help pls re: license lamP
Old Aug 21, 2012 | 06:40 PM
Mike_ses1125's Avatar
Mike_ses1125
Unhappy Help pls re: license lamP
Hi guyz i need help, i have a 2012 mini countryman and i wanted to change my license lamp to led and i think i broke the lamp. 😔 im trying to put it back on it doesnt fit well. It has a metal thing that stick out from the lamp but i dont know what to do with it? I might have bend it 😔 pls help any pics of the oem lamp? Thanks in advance thx
Old Aug 21, 2012 | 07:52 PM
sbdubya's Avatar
sbdubya
Do not follow the owner's manual for removal or installation as it is wrong.
You need to slide the housing from left to right. The metal piece is a tensioner that holds it in. When you are looking at the housing there should be two L shaped catches on the right. Insert these first in the right of the opening and then pop the housing into place.
That should do it. If you need a reference remove the other housing and look at it.
Hope this helps and good luck.
Old Aug 21, 2012 | 08:10 PM
Mike_ses1125
Thanks for the reply but i think its too late. I opened it the opposite way ��cuz of the stupid manual. Do u think i could just bend the metal back?
Old Aug 22, 2012 | 08:28 AM
sbdubya's Avatar
sbdubya
Remove the other light housing and use it as a reference to bend the tensioner back into shape. If that doesn't work then I guess you'll need a new one.
You can go on sewellparts.com and reference it in a diagram if you need a new one. Then you can cross reference it against other MINIs as I'm sure it is the same part and you might be able to find a used one on ebay.
I have not looked at the light housings under the doors if you have access lighting. If it is the same you could use one of those until you get the replacement.
Old Aug 22, 2012 | 04:49 PM
Koopah's Avatar
Koopah
The light housings under the door ("puddle lamps") are entirely different. I screwed up one of my license plate lamps and couldn't bend the copper strip back into shape accurately enough for a tight fit. Ordered a new LP lamp for less than $20, IIRC.
Old Aug 26, 2012 | 06:30 PM
kconner5's Avatar
kconner5
I also followed the manuals instructions when replacing the license plate lamps with LED's... Thankfully I was able to bend it back into shape for a tight fit.
Kyle
Old Aug 26, 2012 | 08:24 PM
Mike_ses1125
Old Aug 26, 2012 | 08:27 PM
Mike_ses1125
Thanks for the reply guys i was able to bend it but not that much, so i ended putting a double sided tape. Btw i was surprise ddm led is not throwing up a bulb out warning. Next step retro fitting an hid. Thanks again.
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:13 PM
point665
Sep 29, 2015 12:41 PM
