Interior/Exterior 2 Days Old CMS4 let the modding begin, JCW, Black Out & KW V3 shortly
Old 07-16-2012, 06:59 PM
advantyper's Avatar
advantyper
advantyper is offline
Hi All
Inspired by the mods by other members on the forum. I order the JCW lip before my car even arrive
Picked up my CMS4 Manual on Saturday, installed the JCW lip in the afternoon, following the instruction on this forum.
Next Plasti-Dip all the chrome pieces in the front and back. I even plastic dip the license plate frame, which looks pretty sweet.
Got the windows tinted today, 20% in the rear and 30% in the front.
Spray Tinted the side markers/reflectors
Ordered a set of KW V3 and SPC Lower Control Arms, will installed those once they arrive.
Think the car will handle way better after the Coilovers are install, love the V3 on my other car. Plan to set lowering @ 2" front & rear
Happy Modding
Attached Thumbnails 2 Days Old CMS4 let the modding begin, JCW, Black Out & KW V3 shortly-cms.jpg   2 Days Old CMS4 let the modding begin, JCW, Black Out & KW V3 shortly-cms2.jpg
Old 07-17-2012, 08:10 AM
TheSuspensionSource's Avatar
TheSuspensionSource
TheSuspensionSource is offline
That is going to look so dope once it is lowered!
Old 07-17-2012, 09:35 AM
Braminator's Avatar
Braminator
Braminator is offline
dope? what year are we in. come on its fresh.
Old 07-17-2012, 10:05 AM
TheSuspensionSource
lol either one works.
Old 07-19-2012, 12:37 PM
advantyper's Avatar
advantyper
haha, tks Kris
Looking forward to getting the coils and control arms install next week
Old 07-19-2012, 07:52 PM
MSPRO's Avatar
MSPRO
MSPRO is offline
Looks nice. Could you take a side shot to show how the JCW lip looks like with the non JCW side skirts and rear?
Old 07-21-2012, 07:17 AM
advantyper's Avatar
advantyper
Sure, will do after my coils are install
Old 07-21-2012, 08:15 AM
CZ Mate's Avatar
CZ Mate
CZ Mate is offline
Thanks for building me my countryman all4. When are you going be dropping it off.. Lol that's is really how I want mine to look. Looks great :-)
Old 07-21-2012, 09:24 PM
advantyper's Avatar
advantyper
Tks, Getting the coils installs on Thursday
Old 07-21-2012, 10:51 PM
MSPRO's Avatar
MSPRO
MSPRO is offline
Thanks. Can't wait to see pics of it lowered.
Old 10-04-2012, 12:47 PM
Craigeo's Avatar
Craigeo
Craigeo is offline
Might be a dumb question, but do you need to remove the trim rings to plasti-dip them? Is it a spray-on system.. Never used the stuff! Also, if you do, how do youget the front and rear light trim rings off?
Old 10-04-2012, 02:26 PM
dpike's Avatar
dpike
dpike is offline
i think it comes out a lot cleaner if you remove them rather than tape them off. plastidip isn't hard to spray, you can get a can at home depot for like 5 bucks. it's sprays a little thickish so be careful. use 3 light coats then look at them in the sun to make sure the chrome gets covered well. if you don't like the way it comes out, let it set and peel it off and give it another go. the stuff is really that easy to use, but over spray is tough to remove because it doesn't have the buildup thickness/tension to be able to peel right.
to remove the front rings there's clips on the underside of the bonnet, just carefully push them back with a small screwdriver or something until they release from the bonnet, then work your way around. some go easier than others maybe give each of them a little try until you get a good starting point.
to remove the rear rings there's two vent covers on the sides in the boot, remove those and look up to your breaklight. you'll see two clips on the outside edge on the upper and lower sides. remove those then carefully swing the taillight out away from where you removed those clips, it may at a little bit of force, but it will go (it's still being retained partially by the two matching inner clips like the ones you removed but can't see through the vent cut out. if you feel up the inside of the light you can feel them tho.) once it pops, be careful there's studs on the back and that you don't want to scratch your paint, maybe have someone else hold the light while you disconnect the wiring harness. remove the chrome trim from the light housing by the little clips around the perimeter with a small flat screw driver or something and paint away.
to put the fronts back they just snap back into place, to put the rears back... loosen, just a turn or two the two inner clips on each light then reseat the light the same way it popped out, by pushing in on the inside edge first. once you have it where you THINK it's in place have someone hold the light and pull a little on the inside edge of the light making sure you have those two inner clips seated, but without them being lose (you might have to play with the amount of turns on the inner clips to get this right). when the inner clips are seated reinstall the outer clips and reconnect the wiring harness through the vent cut outs in the boot.
it's all really not as difficult as that sounds there's just a little trickery to get that rear light on and off.
Old 10-04-2012, 08:22 PM
Tom W's Avatar
Tom W
Tom W is offline
Sweet man, looks good
Old 10-05-2012, 09:09 AM
advantyper's Avatar
advantyper
Yea, u have to remove the rear tail lights, then release the little snaps, to spray the rings.
There are a few instructions on this forum on how to remove the front and rear rings.
The front rings there are metal clips that you have to release.
The rear lights you have to unbolt 3 bolts per light then you depress the plastic snaps and it come off easily.
The front grill you have to unbolt the grill, then you need a few small flathead screwdrivers and you depress several clips at once and you pull off. This step takes a lot of patiences and time, otherwise you will be breaking quite a few clips
Cheers
07-16-2020 12:54 PM
12-23-2015 10:36 AM
tr3y003
10-22-2015 10:48 AM
08-07-2015 08:02 AM
PatrikKN
08-05-2015 09:10 PM
Quick Reply: Interior/Exterior 2 Days Old CMS4 let the modding begin, JCW, Black Out & KW V3 shortly
