Interior/Exterior OutMotoring Gen2 Custom Gauge Face Replacements
Old Jan 21, 2013 | 09:54 AM
  #76
bmwr606's Avatar
bmwr606
Originally Posted by OutMotoring
whoa, I thought I had researched the part numbers about a year ago and found different part numbers for the R60 BUT as you noted the speedo is the same on all gen2 models including the countryman....so this means the gauge faces we currently offer WILL fit the R60!!
your welcome LOL
sooo ... i want black faces, tach with minor ticks at every 100 rpm and speedo with minor ticks every 2 mph
can do or counter offer?
thanks
scott
Old Jan 21, 2013 | 09:55 AM
  #77
MyroMini's Avatar
MyroMini
These are custom printed as ordered and take about 2 weeks for printing and are shipped direct to the customer from Canada....
Shipped from Canada? So If I buy these, I won't pay any duty? Sweeeeeeeeeeet
Old Jan 21, 2013 | 10:11 AM
  #78
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
Yes, that is correct...
Old Jan 21, 2013 | 10:12 AM
  #79
OutMotoring
Vendor - 15 Years
Originally Posted by bmwr606
your welcome LOL
thanks
scott
well, the graphics were completed long ago and at this point we would not be able to do a variant of the design without making a big mess...
Old Jan 21, 2013 | 10:26 AM
  #80
bmwr606's Avatar
bmwr606
i just looked at the R58 gauge faces ... a tick every 100 rpm would be too much, i can live with every 200 rpm
scott
Old Jan 21, 2013 | 10:29 AM
  #81
bmwr606's Avatar
bmwr606
i thought i wanted black faces, but i see you have a checkered design
can you post a photo?
thanks
scott
Old Apr 7, 2013 | 02:38 PM
  #82
user 837978240's Avatar
user 837978240
The speedometer needle is easy to take off.
The tachometer needle is a PAIN in the rear! Cannot take it off. This is for Gen 2.
Old Apr 7, 2013 | 02:54 PM
  #83
SMOG's Avatar
SMOG
Alliance Member
So how did you get the Speedo needle off?
I purchased a used Tach to test the needle removal and did get it off but I don't think it would work correctly again. It feel like it has tight spots in its rotation now.
Old Apr 7, 2013 | 02:56 PM
  #84
SMOG's Avatar
SMOG
Alliance Member
well, the graphics were completed long ago .
AARON:
How do you get the needles off! A "How To" please
Stephen
Old Apr 7, 2013 | 03:10 PM
  #85
user 837978240
Indeed, my tach needle is off for sure. Sits toooo low now at idle.
Speedo needle will pull off, takes a bit of tugging..but pull evenly and it will let loose...it's a pin-based needle (means there's a shaft connected to the needle.
Old Apr 7, 2013 | 03:59 PM
  #86
SMOG's Avatar
SMOG
Alliance Member
The Tach, as you must have found out is the same isn't it? I had to rotate it up against its stop and pull at the same time.
The only thing I did not try was a hairdryer to heat the plastic before removing it, with something between the needle and the Tach face to stop heat transfer to the Tach.
Old Apr 7, 2013 | 04:36 PM
  #87
user 837978240
My friend Simon at essentialmini.co.uk is going to make a video of how to remove the tach needle. Will ask permission to post here as well.
Old Apr 7, 2013 | 04:39 PM
  #88
SMOG's Avatar
SMOG
Alliance Member
Needle removal
Excellent! Looking forward to a video, provided you get the necessary permission Good luck!
Old Apr 9, 2013 | 08:29 PM
  #89
user 837978240
Haven't heard on permission yet.
But, I was able to remove the needle, reset the tach and reinstall the needle. All is good again. w00t!
Here's a pic of the tach after needle removal. What do you know, there is a spindle there.
Old Apr 9, 2013 | 08:34 PM
  #90
SMOG's Avatar
SMOG
Alliance Member
How the heck did you get it off!??!
Old Apr 9, 2013 | 08:36 PM
  #91
user 837978240
Held the needle with my left hand. In my right hand, used a flat head screwdriver to put underneath the needle base. Then, while pulling up with the screwdriver, twist the screwdriver in a clockwise and/or counterclockwise motion so it acts like a wedge. The needle will "pop" off.
Hoping I get permission to use the video. It's very helpful explaining how to do it.
Old Apr 9, 2013 | 08:56 PM
  #92
SMOG's Avatar
SMOG
Alliance Member
I tried that, then put two screw drivers under it and pried from opposite sides evenly. I got nothing until I twisted the needle up against its stop and kept rotating. Not good.
I will have to look more closely at my tach.
Thanks!
Old May 19, 2013 | 09:52 AM
  #93
wzabrouski's Avatar
wzabrouski
Waiting for my set for my R60. Should ship tomorrow. Curious about how the speedo gauge is installed. I know she I had these on my R53, I had to remove the speedo. Is it the same on the 2nd Gen/R60?? Thanks
Old May 19, 2013 | 10:32 AM
  #94
Sacred Disorder's Avatar
Sacred Disorder
Got mine about a month ago. Pulled both needles off by hand. Hardest part is getting the speedo back to zero. I was able to use a 90 degree pick to leave the speedo installed and just pry the plastic tabs up.
Old May 19, 2013 | 10:48 AM
  #95
Kirby11's Avatar
Kirby11
What year do you have?
Old May 19, 2013 | 11:25 AM
  #96
Sacred Disorder
Originally Posted by kirby11
what year do you have?
2010 r55
Old May 22, 2013 | 02:39 PM
  #97
nskripsky's Avatar
nskripsky
When I did the original beta fit-up for OutMotoring, that was the part that I had the most trouble with. I thought I had it zeroed, put everything together, and it went backward past zero... BAH!! LOL
Either way - They still look great, and I'm still super happy with them.
Old May 25, 2013 | 11:47 PM
  #98
Sacred Disorder
I agree they look stunning. Getting them to read zero was the hardest part of the install lol.
Old May 26, 2013 | 05:06 AM
  #99
SMOG's Avatar
SMOG
Alliance Member
Looks like I need to get the intestinal fortitude to try getting the tach needle off, again. but this time on the tach in my vehicle.
When I tried it with a sacrificial junkyard tach I wrecked it trying to get the needle off and I am sure it will never work properly, if at all, ever again. There are tight spots in the rotation now. I am inclined applying heat, like hair dryer or low setting heat gun, to the needle before trying to lift/pry it off, all the while using a heat blanket material to keep heat off the tach.
Did anyone try this method??
Did Outmotoring Post a "How To" video?
Old Jun 1, 2013 | 01:43 PM
  #100
wzabrouski's Avatar
wzabrouski
Did you guys completely remove the speedo to change? If not, how did you remove the piece in the photo. On the countryman it is behind the clear cover and I am trying to figure out if I can replace gauge face without removing the speedo. Also, I found that once you change the face, plug the tach in, it will reset and you can see if the needle is where it should be. I actually plugged the tach in, then put the needle on, checked and reassembled the tach. Is the speedo I am trying to figure out.
Attached Thumbnails OutMotoring Gen2 Custom Gauge Face Replacements-image-2684106714.jpg
